New garage
I built a 36x50 with a 16x50 loft 2 years ago.
When I started putting stuff in it I realised I should have built it 10 feet longer.
Then again maybe I should just start getting rid of some of the stuff.
NOT! I want more!
NOT! I want more!
Here's a post that sure brought out the jealous man in me...
I sure wish for one like that, hopefully someday!
I did build a 10x14 workshop in the back yard 4 years ago, mainly for storage and it has really helped out. The electrical and insulating work was more time consuming than the wood building part it seemed...
Just be careful during its construction... I ended up in the hospital 3 years after trying to pick up an A/C unit by myself. -Another one of those stupid things I did back then...
Looking good, three doors are always better than a big and little, now you need three openers so don't forget the three receptacles in the ceiling.
I've built at least a hundred garages and no matter how big you make them they end up too small. The junk is only "good junk" if you have a place to put it, then when you run out of room and throw it out it's just regular junk again.
Not fair,
I looked at this knowing that I have to start my disc brake conversion which will require me to move several items from my two car garage to the carport and stack them on the 48 so I can get enough room to work aroud the 57. I hope to build my shop in the next year or two. Just a litte envious
nice garage. i recently move into a house that has a six car garage. it originally was a two car and they took the back wall out and add a four car with a single door in the back. it was out of my budget but how could a man pass it up.
. its a total of about 1200 sq ft.
Is the wiring finished yet? cable, water, air conditioning and heat?
My dentist friend is now single and his car hating wife got the house. He has a bunch of cars and bikes so he had a warehouse built in an industrial park and keeps all his stuff in there and lives there too, lots of room. The warehouse isn't zoned for residences but he maintains a low profile.
I met his new girlfriend at a cruise-in and all she wanted to do was leave because it was boring, some guys never learn.
My carbarn is just the right size for me. Any larger would be (more) dangerous and get me into (more) trouble.
(Not meaning trouble with the wife, though....she wants to add on to it!)
I house 5 cars there (could hold 6).
Radiant tube heat! Superbly efficient.
Very nicely done. Unfortunately, If it were mine I would have the outside porchs cluttered up with parts/pieces also.
Never enough room!
I built a 30x40 garage and it is just right to hold a 71 cutlass, 71 chevelle, 37 plymouth, and sideways in the back there is room for the workbench and a 39 dodge. I live in a rural area so just use truck boxes for storage.
Some nice garage photos. I wish I could do that. I live on Long Island where space is at a premium, I am lucky to have a two car garage. My wife gets one of the spots but at least she let me get a lift so I could put two on one side. That definitely helps but I wish I could build a man-shed like some of yours! Maybe some day.
Thanks for the comments, I've been needing one of these for many years. Jamesbo, it'll have popane heat but haven't decided what style. A friend helped me run electric to it last Monday while it was still warm. Right now I'm waiting on a kerosene heater to warm the coffin up so I can start on the wiring. It's colder than the devil here and about all we get done in this cold is feed cattle, so time to wire. I've a small storage building behind it and hoping not to clutter this one up.
I'll get some pics of my cars in it Olds64 and great carbarn wmachine.
Man I am soooooooooooooo Jealous!!!!!!!!!
Wow great car collections Great garages and Car barns? new one for me LOL... Old Skool I use to live out in stony brook Li, I know what your saying, but i am in jersey for over 20 years now and all i have is a 1 car garage! albeit, my wifes ( when it was new) car was in the driveway LOL.. and my 69 cutty was in the garage LOL...
Actually, carbarn is a very old term for buildings used to house railroad cars, streetcars and such.
At the risk of sounding like a pig, I have a regular 2-car attached garage also. It immediately got confusing when the wife or I said "garage", so I needed a way to identify them, and decided to call the big one a "carbarn", reviving the old term.
It seems to be the staging area for trash and junk parts that never seem to leave.
A water heater joined the pile a couple days ago...
Eddie,
You seem to have the same amount of workspace as I do...
awwwwwwwww Man I pity you too.... LOL. I mean these "other Guys" car barns and tool sheds, machine sheds too LOL... nothing like twisting the knife brutha LOL....
I actually took the fenders, interior, and stuff I am not working with down to the basement just to make more room...
one day..... I'll have a Man Garage..
right now I got the deluxe munchkin garage for an OzMobile LOL
You may want to look at replacing the POA valve when you do the expantion valve. It;s the weard looking tube that has all of the small lines comming out of it. These things give lots of problems when they get old. I had to chang them on my 71 chev. truck and a 71 Cutless that I owned. They run about $100 and can cause all cinds of problems when they go bad. The conversion also gives you a low pressure switch for the compressor.
When you build your garage you might consider putting hot water heat tubes in the floor. My buddy hooked his to an outside wood burner and has a propane hot water tank as a backup heat source. The floor is always nice to work on and if you paint there is no dust blowing around.
I'm quite satisfied with my "SunTube" gas radiant tube heater. Extremely efficient, no open flame, no moving air. Also, since it heats objects and not the air, going in and out of the building results in minimum heat loss.
If you are looking to heat that garage, find your closest dealer that sales Hired Hand gas heaters. They have a 225,000 btu for chicken houses that will do all you want in a 3000 sf or smaller shop. They cost around 550.00
You will not regret it. Does not burn much gas either. You can get them in natural or popane models. I have 2 of them in my shop. 50x75
Model STG-85-25MBN
http://solaronics.thomasnet.com/item...=prod&filter=0
Jamesbo, I'm not sure what you're looking for, but it is a highly efficient heating system. Widely used, but not well known. They call it "infrared" heat, but I've always called it "radiant" heat. The website explains it pretty well:
http://www.solaronicsusa.com/infredb.htm
Physically, it is a long tube with a reflector. Gas fired with the inlet and outlet of the tube from and to outside air. So no exposed flame inside the building.
It heats objects, not the air. Ideal for warehouses and open air buildings. opening and closing door don't lose as much heat either.
You can see it in the upper right of the pic.
Jamsbo, this type of heat is used in a lot of manufacturing buildings because it directs heat to a given area. great for over work stations. The down side of it is that if your under the car the heat does not reach you. The in floor radiant heat using hot water is great for garages because heat rises so you have warmth everyware. It also is cost efficent and can be done with a gas or electric hot water tank or boiler which can also heat hot water for a cleanup sink. Then if you install paddle fans that turn at low speed it will circulate the heat and keep it from staying at ceiling. In the summer the same paddle fans can help cool the garage. You can also use a wood burning boiler if you have access to wood. Of course the key to efficent heating of any garage is insulation R-30 in the ceiling and R-19 minimum in the walls also insulate the garage door which is the largest source of heat loss in a garage.
Thanks for all the great ideas. The concrete is done so it will be propane or wood heat. I've finished the wiring and have my lighting up, may put up more. Next on the list is insulation because DANG!! it's cold. I'll be getting some pics up.
I hope you used calcium in that concrete if it's that cold or it will take forever to dry. Even if you did It probably won't be fully cured before the middle of summer if it's cold there as here.
If you have a lift you would have to wait awhile for the concrete to cure enough to put a car on it.
Just don't park any of those cattle or any army tanks on it and it should be fine.
A few of those big critters in there would probably heat it up good and stuff.
It probably would be mostly stuff, all over your new floor.
If you have a lift you would have to wait awhile for the concrete to cure enough to put a car on it. Just don't park any of those cattle or any army tanks on it and it should be fine.
But it may be surprising that many of you how much the insulation keeps in the cool over the summer too. Especially on the sweltering hot summer days, it is remarkably cooler and less humid inside. There are times in the summer when I keep it closed up up to keep the heat and humidity *out*. (I should also note that it gets a fair amount of summer tree shade).
The insulation is the fun part.
Do the Tom Sawyer whitewash fence trick and convince bystanders to pay you to let them do it.
Good ventilation is the key, the best way to keep a building cooler in the summer and warmer in the winter is a roof vent fan and proper venting in the gable ends or overhangs, lots of roof vents at the least.
) have fun with it .
