Neutral Satey Switch question
Old Nov 16, 2016 | 05:02 PM
O-dawg's Avatar
My 72 cutlass's back up lights dont work.....The car will start in any gear which makes the neutral backup safety switch suspect.Now I brought a new one but before I install it Im trying to understands exactly how they work.......When I shift my floor shift th350 shouldnt the steering column rotate the little thing on the neutral saftey back up switch....I ask because earlier when I was under the dash and I shifted through the gears with the car off....I didnt see anything move on the neutral saftey switch.Am I misunderstanding something?
Old Nov 16, 2016 | 05:46 PM
The backdrive linkage from the trans to the steering column is missing. Either this car was converted to floor shift (and the linkage was not properly installed) or it was removed to clear headers.
Old Nov 16, 2016 | 06:10 PM
O-dawg's Avatar
Wow!Thanks man!I do have headers so maybe thats why they did it........I wish there were something I could do to keep the headers and still run the back drive linkage
Old Nov 16, 2016 | 07:20 PM
svnt442's Avatar
You can make a switch to work on the floor shifter if there is no way to clear the headers. It might take some minor engineering, but it's doable.
Old Nov 17, 2016 | 06:54 AM
Depending on the specific headers, you can often get the backdrive linkage to fit with some minor bending. Failing that, there are aftermarket cables for street rods that run from the steering column to the trans.
Old Nov 19, 2016 | 05:22 AM
O-dawg's Avatar
Thanks man!I do want the car fully funtional even though it is custom to a degree.....There is hope!Thanks!
Old Nov 19, 2016 | 11:55 AM
I had no interference between the headers and the backdrive linkage on either my 70 Supreme or the 71 convertible. Both 350 cars with Heddman headers.
Charly9g
Nov 6, 2016 05:10 PM
oldspackrat
Nov 17, 2014 06:31 AM
footbrake
Jun 12, 2006 06:10 PM
oldsnut7098
Aug 10, 2003 10:06 PM
