My Car Won't Stay On....
Old March 27th, 2013, 12:58 PM
1984supreme's Avatar
My car has recently stopped working correctly, When I start my car it starts perfectly it just cuts off after 2 minutes or so. has anyone had any problems like this or does anyone know how to help it would be appreciated. thank you.
I have a 1984 Cutlass Supreme 5.0L V8 just in case you need to know.
1984supreme is offline
Old March 27th, 2013, 12:59 PM
Old March 27th, 2013, 01:00 PM
Old March 27th, 2013, 01:11 PM
Lansing built
1970cs's Avatar
Can you restart it after it dies?
Pat
1970cs is online now
Old March 27th, 2013, 01:13 PM
yes it restarts pretty well, It dies as soon as I put it in Reverse or drive but it stays on for awhile in neutral and park.
Old March 27th, 2013, 01:52 PM
jaunty75's Avatar
You posted this same thing in four different forums (at least, that's how many I counted). I realize that there are multiple places where it would be appropriate to post a question like this. Pick one of them. You need to post it only once, and it'll get seen by more people that you can imagine.
jaunty75 is offline
Old March 27th, 2013, 02:02 PM
oldsmobiledave's Avatar
answer
As mentioned above no duplicate posts.
Now to solve your problem you only need two things for the car to run... fuel & spark. When you start it you have both then it dies. That means one of the two is no longer present.
Check your fuel & spark delivery & you will be on the right path. I would start with a weak fuel pump and then move onto other fuel factors.
oldsmobiledave is offline
Old March 27th, 2013, 02:09 PM
starfire's Avatar
First thing to do is to replace your fuel filter.
starfire is offline
Old March 27th, 2013, 05:35 PM
Start with the basics. Once the engine stops running, does it still have spark? Is the choke opening correctly? Once it dies, how long before it will start again. Fill in the blanks and maybe we can help.
matt69olds is offline
Old March 27th, 2013, 06:42 PM
Yup. Spark, Fuel, Compression, Timing. That's all there is.
Obviously Spark and Fuel are the most likely to change over two minutes.
Check 'er out and let us know what you find.
MDchanic is offline
Old March 27th, 2013, 07:40 PM
Lady72nRob71's Avatar
Okay, i ~think~ I found all of these and consolidated them...
Please do not post same thread in multiple sections. I left them here in the Cutlass section until we can narrow into a cause of your problem. From there I can move it to wherever needed.
I hope we can help you solve your problem.
Lady72nRob71 is offline
Old March 27th, 2013, 09:21 PM
Rickman48's Avatar
I'd think, since it runs for a while, the sock in the tank is almost clogged solid, and restricting flow about 95%
Pump is usually good or bad, and fuel filter clogged solid or not.
Sounds like this car sat a long while.
Rickman48 is offline
Old March 28th, 2013, 05:38 AM
ls98's Avatar
had this at one time on a pontiac 6000,it would run good with no load on engine, found the pressure regulator in the fuel rail had failed,i found the problem by pinching off the fuel return line,had to replace the the fuel rail,the spring for the regulator fell out when i remove the rail,never did find the ball.
ls98 is offline
Old March 28th, 2013, 08:56 AM
frankr442's Avatar
What's your idle speed?
frankr442 is offline
Old March 28th, 2013, 09:16 AM
Octania's Avatar
Sputtering to a halt is symptomatic of a fuel issue on a carbed engine. Electrical tends to be instant off
I vote for broken wire at HEI pickup coil. When it moves just right, no go.
Pull 1 plug wire at plug, put a spare plug or spark ckr on that wire. Run her on 7, with a helper. Watch the spark as your helper induces the fail to run. As the engine dies you will know right away if it lost spark... then follow the road that seems appropriate.
Octania is offline
'71CS
August 17th, 2021 05:14 AM
stevengerard
September 10th, 2014 03:17 PM
DJS70cutlass
September 7th, 2014 07:33 PM
dlevenseller
November 14th, 2011 06:45 PM
Charlie_brown
August 9th, 2010 03:38 PM
Quick Reply: My Car Won't Stay On....
