It won't stay running!
Old Aug 9, 2010 | 10:27 AM
Charlie_brown's Avatar
the engine starts and immediately revs up to 3000rpm and then looses rpm and dies. If i try and keep it running and give it gas right before the rpm's get too low it'll rev back up to 3k jbut if the rpms are too low it stutters and shoots a flame out the carb. I was told it could be the power valve burned out. The carb is a speed demon 750 vacuum secondaries (no choke).
Old Aug 9, 2010 | 03:38 PM
olds425's Avatar
Have you done any work on it recently. It may be timing but a power valve will cause weird problems.
DJS70cutlass
Sep 7, 2014 07:33 PM
1984supreme
Mar 28, 2013 09:16 AM
yeahbuddy
Jun 1, 2012 02:33 PM
dlevenseller
Nov 14, 2011 06:45 PM
