Looking for body bushings 67 cutlass.
Old Jan 4, 2018 | 07:10 AM
Tugla's Avatar
As title says I'm looking for polyurethane body bushing with the bolts. Energy suspension doesn't have a listing. I see one kit in opgi catalog but not sure on their hardware kit,looks like the cheap bolts in the pic.
anyone ever use a kit for a chevelle/elCamino with sucess?
thanks.
Old Jan 4, 2018 | 08:14 AM
lemoldsnut's Avatar
I used a kit from OPGI and it was fine. I cleaned and reused the factory bolts. This kit does not come with the ones for the core support., They are different. The kit also does not come with the two that do not have bolts through them. I have many used bushings if you end up going that route.
Hope this helps
Larry
lemoldsnut@aol.com
Old Jan 4, 2018 | 09:56 AM
Tugla's Avatar
Don' have the original bolts or bushings...
was hoping to find the "cad/gold" looking bolts vs the reg silver one in opgi catalogue. ..was gonna use rubber but chg mind to polyurethane as I will be racing the car...
Re reading it only says 68 and on you need to buy separate hardware kit...
Old Jan 4, 2018 | 09:58 AM
Tugla's Avatar
Larry, so you saying opgi kit is just missing the 4 bolts (2 rad 2 mid frame) but bushings and rest of hardware is there?
Old Jan 4, 2018 | 10:06 AM
lemoldsnut's Avatar
No, The OPGI kit does not include the two mid body bushings that do not have a hole in them and do not use a bolt, it also does not come with the radiator core support bushings and bolts.
I reused several of my old bolt as I have pulled many of these bodies and had some that were reusable.
Old Jan 4, 2018 | 10:10 AM
You can just buy gr8 bolts for your kit.
Old Jan 4, 2018 | 02:40 PM
Tugla's Avatar
Yup pretty much just gonna buy the bolts, was hoping there was a way to save time and have a kit with bushings and bolts in one...guess not.
Thanks.
Old Jan 4, 2018 | 03:20 PM
There are separate bolt kits, not with gold cad bolts. GR8 bolts are gold cad, found at most fastener/bolt stores.
Old Jan 4, 2018 | 03:26 PM
69 Ragtop's Avatar
But then again, grade 5 bolts are more than strong enough for the body mount application. The sheet metal would rip out before the bolt would break.
Old Jan 4, 2018 | 03:31 PM
The OP wants gold plated bolts, its not a matter of strength.
Old Jan 4, 2018 | 03:42 PM
69 Ragtop's Avatar
Oops. Sorry I posted. I'll try to be less offensive.
Old Jan 5, 2018 | 04:46 PM
Tugla's Avatar
Ya was more for the look vs strength
Old Jan 22, 2018 | 07:51 AM
bblondahl's Avatar
Body Bushings
Yes to get that look use grade 8 bolts. Overkill but they all have the colour you want..
Anyone notice that the retailers for body bushings usually get them wrong. I'm looking for correct bushings for my 68 Cutlass convertible. I have seen them at Fusics, OPGI and Golden Leaf and they are all wrong. The ones at Energy Suspension are correct but I don't want to go Urethane. There are 4 mount locations that are just a rubber bumper ( no bolt) but all the kits for coupe or convertible only contain 2 of those. I was wondering if I could use a standard mount but don't use the bolts or the rebound rubber.
Old Jan 22, 2018 | 08:08 AM
I thought it was for BB cars and there were only 2.
Old Jan 22, 2018 | 09:05 AM
bblondahl's Avatar
There are 2 rubber bumpers (no bolts) below the rear seat location and 2 on the frame above the Diff. Hard to see. I think big block is supposed to have another set at the front for Chevelle but my original body service manual doesnt show anything different for big block for Olds. 68 - 72 different from 64 -67 however..
Oldssupreme
Aug 19, 2016 09:36 AM
rothlane'68
Nov 29, 2015 06:54 PM
epinkston
Nov 29, 2011 10:54 PM
66trifire
Apr 12, 2009 08:50 AM
WindWraith
Apr 3, 2007 05:17 PM
