light lenses
Old Sep 24, 2007 | 07:20 AM
Chumley's Avatar
light lenses
Are the inner tail light lenses for '71 and '72 Cutlass the same?
Thanks, Chumley
Old Sep 24, 2007 | 07:53 AM
Oldsguy's Avatar
Past Administrator
this is a 1971
http://classiccarfair.com/1971_cutlass_rear_559x357.JPG
This is a 1972
http://www.diecastfast.net/images/ho19.jpg
Notice the vertical dividers? On some models they were painted
silver and were more obvious
Old Sep 24, 2007 | 08:49 AM
texasred's Avatar
Tom Servo's Stunt Double
I believe he's talking about the diffusers behind the outer plastic lens, Dan. The answer is yes, they are the same. But upper and lower are not (as I remember).
C.J.
Old Sep 24, 2007 | 12:15 PM
Oldsguy's Avatar
Past Administrator
ooops
Old Sep 26, 2007 | 08:34 PM
Chumley's Avatar
Thanks guys, I thought the lower diffusers would be the same as I know that the uppers are.
Chumley
Old Sep 28, 2007 | 07:26 AM
htlong's Avatar
my tail light lens has 4 screws...3 came out pretty easy the 4th is not coming out willingly so does anyone have any ideas on how to remove stubborn screws with out striping them ,i have tried to tap the screwdriver with a hammer to no avail, I'm going to go buy a easy out reverse type drill bit but was wondering if anyone had suggestions?
Old Sep 28, 2007 | 05:15 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I Jb weld a crappy screwdriver onto it. Make sure you get rid of the rust, but if you stripped it ,chances are it's shiny now. Hope you have some patience for drying time.
Old Sep 29, 2007 | 08:58 AM
The end of the screw actually passes through the light housing and is exposed on the backside. That's why it rusts into the housing. Try getting to the backside of the housing and spray WD40 on the exposed end of the screw after wire brushing off the rust.
Old Sep 30, 2007 | 06:46 AM
Oldsguy's Avatar
Past Administrator
Or PB blaster, I use both products and have found that PB blaster is really good for this kind of thing. It comes out very foamy and doesn't run as easily and I think it breaks rust better. Just my opinion though
Olds92
Jan 3, 2014 09:47 AM
KZ442
Dec 11, 2009 07:57 PM
oldsmobilia
Dec 28, 2008 04:30 AM
oldsmobilia
Dec 26, 2008 02:23 AM
Sixoh
Jun 8, 2008 06:58 PM
