I need some info.
Old Sep 21, 2009 | 03:27 PM
freebird72's Avatar
I need some info.
Does anyone have a wiring diagram for a 72 cutlass supreme’s radio. If anyone has any info could you please help? Anything can help, thank you.
Old Sep 26, 2009 | 08:48 PM
What exactly do you need? There's a whole manual on the radio and tape deck. Are you just looking for the leads for power and speaker hookup? Or do you have a defective radio and are trying to troubleshoot it?
Old Sep 27, 2009 | 08:08 AM
freebird72's Avatar
The only thing that my radio does is light up. So I guess I need everything someone could give.
Old Sep 27, 2009 | 08:33 AM
Unless your speaker wiring is completely hosed, and assuming you have a stock radio, the most likely problem is a bad output power transistor in the radio. These can be replaced.
Old Sep 27, 2009 | 09:13 AM
Bluevista's Avatar
Registered
Do you mean a wiring schematic for the circuitry inside the radio or the speaker/power hook up? I guess you got power.
There should be the two wires from the front speaker going in next to or on the right of the power lead looking at it, which is usually all the way to the left or on the drivers side. If it has a rear speaker there should be a single lead wire with a female plug coming out of the passenger's side, the other rear speaker terminal is grounded to the body.
If the light comes on it may just be the speaker or connection hopefully. Have to make sure the speaker is good first somehow, I didn't and had a good working radio repaired for no reason.
Sometimes the wiring schematic deal with the hieroglyphic symbols for the radio circuit stuff is glued to the inside or outside of the case or folded up and tucked away inside.
Old Oct 5, 2009 | 07:06 PM
Update
Did you ever find out what the problem was? I can scan the repair guide if you need it.
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
mustang_walker
Mar 6, 2008 06:21 AM
pontchief
20
May 8, 2007 05:06 PM
pontchief
Ninety-Eight
Oct 21, 2006 02:56 PM
