help with 77 cutlass egr
Old Apr 21, 2011 | 09:01 PM
rayfrausto's Avatar
I put on a edelbrock carbuerator today, and come to find out the egr valve is blocking the throttle from going all the way back. Directions said egr adapter may be needed. So when and bout the part number it said to and it didn't fit my 350. Anyone no a egr adapter that will fit a stock 350. If not second option will be to take out the egr valve and put a plate on it. What will be the effects of removing my egr. I hear people do it to old cars a lot
Old Apr 21, 2011 | 09:06 PM
Redog's Avatar
The effects of removing an EGR on a car that old will make it take longer to warm up in the cold weather, but it will give you a slight, very slight increase in power
Old Apr 21, 2011 | 09:09 PM
rayfrausto's Avatar
So removing the egr will give me slight power effect.. car taking longer to warm isn't to bad? So all in all it won't really affect me ?
Old Apr 21, 2011 | 09:12 PM
Redog's Avatar
No not really, Just make sure there is no tubing from the cat to the EGR or anything where you're going to have "open exhaust" by doing this. It's been a while since I've been under the hood of an Olds Block, with the emissions. Usually the EGR has a tube running from the ERG itself to the cat. An exhaust shop can weld that tube on the cat closed for probably $20, but they will only take cash!!!
If the exhaust is "open" you'll hear a ticking when the car is running, It's not a valve tap, but it sounds like it.
My Alero has an exhasut leak right now, it's driving me nuts
Old Apr 21, 2011 | 09:25 PM
rayfrausto's Avatar
Okay sounds good ima make a plate to cover it and see how everything goes.. ya cause someone told me it will waste a lot of gas if its not on but that don't sound right so wanted to check
Old Apr 22, 2011 | 03:38 AM
Sorry, but EGR has nothing to do with the car warming up. It does dilute the mixture at part throttle conditions to reduce NOx emissions. EGR is not active at wide open throttle so you will not see any performance change.
Old Apr 22, 2011 | 07:58 AM
rayfrausto's Avatar
Okay I'm not to concerned about any boost in performance... I just want to make sure there are no negatives that's going to majorly effect me
Old Apr 22, 2011 | 04:42 PM
Redog's Avatar
Car will fail emissions, but that's all I can think of.
Removal of an EGR in a newer car, like my Alero, will HURT performance and lower the MPG because of the car's computer
Mike77
Apr 30, 2024 05:54 AM
Chumley
Aug 3, 2008 01:50 PM
SX455
Sep 16, 2007 06:09 PM
81cutlassconvertable
May 26, 2007 05:16 PM
DonFrost
Ninety-Eight
Jun 22, 2006 04:16 PM
