Headers
Old May 12th, 2016, 05:34 PM
crank shaft's Avatar
Headers
Can anybody tell me if A body headers will fit a G body?
crank shaft is offline
Old May 13th, 2016, 07:29 AM
If they did, why would header manufacturers sell different headers for each?
joe_padavano is offline
Old May 13th, 2016, 09:29 AM
Headers
Sorry Joe, I reread what I posted, I guess I should have told the whole story,my son wants to put a 1972 Olds engine in a 1980 Malibu, he wants to put headers on it and we have a set of headers for a A-Body. Was wondering if I could use these headers, do you know if a 1980 cutlass came with a V-8? I know it's a G body but I'm not sure if I can get a set of headers to work.
Old May 13th, 2016, 09:32 AM
All 1978-1988 Cutlii (and all 1978-1988 A/G body cars from all divisions) use the same chassis - at least from the firewall forward. A small block Olds V8 was offered in every one of those years. Again, if the A-body headers did fit the 78-88 cars, there would be no need for header manufacturers to sell different ones for the newer cars. Get the correct headers.
Old May 13th, 2016, 09:34 AM
[QUOTE=joe_padavano;919752]All 1978-1988 Cutlii (and all 1978-1988 A/G body cars from all divisions) use the same chassis - at least from the firewall forward. A small block Olds V8 was offered in every one of those years. Again, if the A-body headers did fit the 78-88 cars, there would be no need for header manufacturers to sell different ones for the newer cars. Get the correct headers.[/QUOT. Thank you Joe!
Old May 13th, 2016, 09:37 AM
Thanks Joe , I will call Summit after work, can you recommend a set that would fit nice and not hang down to low?
Old May 13th, 2016, 09:50 AM
Joe, being all of the G-bodys were the same, were all of the exhaust ports the same from Chevy to Olds? Or do I need to order cutlass headers to match the Olds exhaust ports?
Old May 13th, 2016, 09:58 AM
You need headers for a 350 Olds in a G body. 350 Olds heads/ ports has nothing in common with a 350 Chevy.
oldcutlass is online now
Old May 13th, 2016, 12:15 PM
Oldsmobile exhaust flange:
Chevy exhaust flange:
Old May 13th, 2016, 12:17 PM
Thanks Joe! I will order a set for a 1980 cutlass!
Mike
Old May 14th, 2016, 07:00 AM
Thanks old cutlass!
Wyze
March 18th, 2012 01:59 PM
martine
February 13th, 2007 11:57 AM
JoshF85
January 24th, 2006 10:20 AM
javi58
April 20th, 2005 07:53 AM
<72>
November 11th, 2004 09:09 PM
Quick Reply: Headers
