head lights
Old May 7, 2014 | 03:31 PM
johnnyjaws's Avatar
head lights
finally recived my 70 cutlass s high beams come on but no low beams any one can tell me what to look for bulbs are good
Old May 7, 2014 | 03:57 PM
Do the high beams in your low beam lamps work? I would first make sure the low beam portion of the lamps are good by jumping 12v directly to the lamp. If they work check the high beam switch.
Old May 7, 2014 | 04:58 PM
Octania's Avatar
Lamp failure is by far more common
after that the hi/lo floor switch
then maybe the dash switch.
After that, it's get the wiring diagram out and work back from lamp to battery
Old May 8, 2014 | 06:33 AM
jaunty75's Avatar
Replace the dimmer switch on the floor. It's about $10, is easy to do, and replacing it fixes about 90% of headlight electrical problems (assuming the lamps themselves are good and the connectors to them are clean and tight).
Old May 8, 2014 | 06:57 AM
Nope, sorry. If ANY headlights are working, the dash switch is fine. There is only one headlight wire out of the dash switch, which runs to the dimmer switch. The dimmer has two wires out, one high beam, one low beam. These are then daisy-chained from one headlight to the next.
A test light probing the headlight sockets is the correct way to troubleshoot this problem. Either you have +12V at the low beam terminal or not. If you do, replace the bulb. If not, figure out why.
Old May 8, 2014 | 09:34 AM
Octania's Avatar
Shine on, you crazy diamond
that was succinct and spot-on, Joe
Old May 13, 2014 | 07:41 PM
johnnyjaws's Avatar
bought 4 new lights from rock auto and everything works now went to advance auto and they wanted 15.99 for one light got all 4 from rock auto plus shipping for 27.00 and was here in 2 days
Old May 13, 2014 | 07:53 PM
Glad to hear it was something simple.
scooter123
Sep 28, 2013 07:32 PM
65droptop442
May 5, 2013 12:21 PM
devmar07
Feb 23, 2012 04:40 PM
oldstuff
Sep 13, 2011 08:03 AM
Sid
Sep 10, 2010 02:33 AM
