got a 72 today
it has the "f" block and Ga heads(supposedly ported)..2500converter..boxed rear arms,rear sway bar,new 3" exhaust with flows,disk brakes,new master,calipers,rotors,lines,new radiator,tach on the column,autometer gauges. plans are to part it out.keep the 455 for my car and some other stuff...its rusty,both fron fenders,rear qtrs and trunk are rusty,i think it was a vinyl top car too. looks like its been 3-4 different colors...lol ive bnever seen one with the tach/clock in the dash before..have only driven it on and off my trailer.had 07 tabs and to bad front tires..
It doesnt look too bad in the pictures, but too bad about the rust.
The clock and tach (tic toc tac) was part of the rally pac. The left gauge should have temp, oil, and fuel gauges.
IF you do start parting it, PM me if you choose to sell the rear sway bar and the fasten belt light on the top of the dash.
You must have gr8 eyes, I couldn't see the fasten belts light pod on this car. If you're still looking for one, I'll put it on my watch list for when I go to the wreckers. That pod got used on a lot of cars, not just Olds. If I see any, I'll pick em up and stock em for anyone who's still looking. It took a long time to find the one I got from ebay. Can't remember if you did the rally pac in Lady yet? If yes, then did you disconnect the seat belt warning buzzer wire from the sender or just leave it? The only thing I don't know is if there's an extra set of wires that will run from the center of the dash to the connector behind the old gages. The pod I've got, the wires are only about 8 inches long. That's definitely not long enough, but easy to splice in.
Out of morbid curiosity, is the hood original (steel frame underneath) and is it up for grabs or ya gonna hold onto it? You're right, it is a cool hood. Needs some work, but still cool.
Yep, did it LONG ago!
Leadfoot - sorry to stomp across your thread...
on the left is just a gas gauge...yes is an original hood with steel under it,i think before i sell the hood ill do paint removal and fix the hole in it,but before i sell anything i need to do a vin check and the trim tag info...i planned on keeping the boxed rear arms and sway bar for my car..it was close to dark when i got home.tomorrow ill be able to drive it and look at it closer..
heres the vin and trim tag info..i didnt see anything to lead me to believe this is a 442.. it does have the "U" in the vin telling me its a factory 455 car..otherwise nothing special unless you guys know somethng i dont..if ya do enlighten me...its otherwise gonna get cut up...
3g87u2zxxxxx
st 7233687 z 021127
tr 940 a52 65 65
11c 04115 0 650262
3g87u2zxxxxx
st 7233687 z 021127
tr 940 a52 65 65
11c 04115 0 650262
A couple thoughts, have you compared the vin number on the engine to the one on the dash? If it's a replacement motor, did the guy you bought it from know the story on the engine he replaced? In 1972 there wouldn't have been anything to show it's a 442 in the vin. Have you checked to see what kind of emblems were on the car before being painted primer red? From the top picture it looks like a 4 row radiator top plate. That plus the 455, the OAI hood and factory tach doesn't mean it was a 442, but I'd be sure I checked everything before cutting it up, those are nice options for a Cutlass. It also was painted flame orange with a black interior, a pretty sharp car when it was new. My thoughts, check it out real well before stripping it, you may just want to fix it or keep the motor/transmission and sell the rest to someone else to fix. John
i have not checked the motor vin,it is a vinyl top car.i thought 442s didnt have vinyl tops? shouldnt the trim tag say w-29 if its a 442?haent really looked at the body for the emblems.its a bench seat car.theres a local guru i know i was gonna call him tomorrow and have him come look at it and see what he thought..it wouldnt hurt my feeling at all to remove the motor ,tranny and a few other items for myself and sell the car whole..i just dont yet have enough info to decide what i need to do..
I'm not an expert with 1972's but I don't think it has to have a W29 on the trim tag to be a 442. If it is the correct motor and or transmission (both have a vin number stamped in them) you might be better off to restore this one. Or at a minimum sell it as a project car and take the profit to buy/build another engine. I have a 1967 and 68 442's that came with bench seats so that wouldn't surprize me. They way I keyed out your trim tag I don't believe it came from the factory with a vinyl top. But I also believe vinyl tops were options on 442's. John
"the motor is original for the car...."
Cool! Well, do you have an idea what it would take to save that car? Any evidence what kind of emblem holes were covered over with body filler? When you pick up an old car you never know what your giong to find
John
John
this car definately had the chrome on the side..holes for cutlass emblem on both front fenders,chrome holes on front part of rear qtrs.and on the doors..did 442s have chrome on the sides?
Yup, some of them sure did. Don't forget that 442 in 1972 was simply an option with upgraded engine, suspension and appearance. There were plenty of cars that came with body side moldingsm=, wheel opening moldings, and the rocker moldings as well. If you had a vinyl roof from the factory, also look for body piercing by the rear 1/4 window and the rear window. (a sure source of water entry over time) Those moldings were held on with speed nuts from inside the sail panel.
im gonna part it...i believe after looking at the body closely,it has cutlass emblem holes in both front fenders a trunklid,and glovebox door..im pretty confident it isnt a 442..rear bumper isnt the cutout one..doesnt look to me like its ever been off. so it goes under the sawzall very soon,ill list parts for sale as i get around to removing them...may be awhile as its more important to me right now to move forward on my car.
Leadfoot, your car was code 65 Flame Orange with a painted Flame Orange top. A52 indicates a bench seat. 1972 W29 cars never had the W29 code stamped on the trim tag either. If they did, it would save a lot of agonizing among '72 owners who don't have build seets with that code on it (and it would weed out a lot of clones too).
Terry
This is how people get confused... NONE of the 1970-72 442s had factory side body moldings down the middle like an S or Supreme. They did have trim around the wheelwells, drip rails and vinyl tops, but not on the sides. W29 cars had the thin triple pinstriping, which are in almost the same location down the sides that the moldings would be. No lower rocker stainless either.
Terry
Terry
BTW thanks for the A52 ref. It's on my cowl tag too, but not in the SPECS book. Do you know why this would be put on the cowl tag? The car has certainly got more than that for options which were not standard equipment for that model.
I'd encourage you to create a parts wanted thread and see what gets offered up.
John
I did in parts wanted , I did find a guy on here with 4spoke steering wheel all mounting hard wear just missing horn button I'm waiting to receive it now.... Thank you though
