got a 72 today
Old Nov 27, 2009 | 04:48 PM
leadfoot067's Avatar
got a 72 today
found on CL.. fresh 455,t-400,and the cool hood!!
Old Nov 27, 2009 | 04:53 PM
Lady72nRob71's Avatar
Good score! What are the plans for it? Does it drive okay? Looks like the PO over-revved it and spun the tach a bit...
Old Nov 27, 2009 | 05:14 PM
it has the "f" block and Ga heads(supposedly ported)..2500converter..boxed rear arms,rear sway bar,new 3" exhaust with flows,disk brakes,new master,calipers,rotors,lines,new radiator,tach on the column,autometer gauges. plans are to part it out.keep the 455 for my car and some other stuff...its rusty,both fron fenders,rear qtrs and trunk are rusty,i think it was a vinyl top car too. looks like its been 3-4 different colors...lol ive bnever seen one with the tach/clock in the dash before..have only driven it on and off my trailer.had 07 tabs and to bad front tires..
Old Nov 27, 2009 | 05:57 PM
It doesnt look too bad in the pictures, but too bad about the rust.
The clock and tach (tic toc tac) was part of the rally pac. The left gauge should have temp, oil, and fuel gauges.
IF you do start parting it, PM me if you choose to sell the rear sway bar and the fasten belt light on the top of the dash.
Old Nov 27, 2009 | 06:06 PM
Originally Posted by Lady72nRob71
..............IF you do start parting it, PM me if you choose to sell the rear sway bar and the fasten belt light on the top of the dash.
Hey Rob,
You must have gr8 eyes, I couldn't see the fasten belts light pod on this car. If you're still looking for one, I'll put it on my watch list for when I go to the wreckers. That pod got used on a lot of cars, not just Olds. If I see any, I'll pick em up and stock em for anyone who's still looking. It took a long time to find the one I got from ebay. Can't remember if you did the rally pac in Lady yet? If yes, then did you disconnect the seat belt warning buzzer wire from the sender or just leave it? The only thing I don't know is if there's an extra set of wires that will run from the center of the dash to the connector behind the old gages. The pod I've got, the wires are only about 8 inches long. That's definitely not long enough, but easy to splice in.
Old Nov 27, 2009 | 06:10 PM
Hey leadfoot,
Out of morbid curiosity, is the hood original (steel frame underneath) and is it up for grabs or ya gonna hold onto it? You're right, it is a cool hood. Needs some work, but still cool.
Old Nov 27, 2009 | 06:53 PM
Originally Posted by Allan R
Hey Rob,
I did not either - I am going on assumption that the rally pac on this car was factory and the fasten belt light is on the dash...
I do want one, though it is not too important. Basically i just want the top part that i can stick to the top of the dash for that "factory look". I do not have the heart to actually cut a hole in the dash for the wiring.
Yep, did it LONG ago!
After rearranging the wires in the connector, the fasten belt light wire was heatshrinked and left hanging. I did reenable the annoying buzzer, so front seat occupants must fasten their belts!
I would be curious to see the factory rally pac wiring harness...
Leadfoot - sorry to stomp across your thread...
Old Nov 27, 2009 | 07:29 PM
2blu442's Avatar
Congrats on the new car! Too bad its rusty, but if you can use some of the parts on your car and sell/trade the rest your going forward on your project. John
Old Nov 27, 2009 | 09:41 PM
on the left is just a gas gauge...yes is an original hood with steel under it,i think before i sell the hood ill do paint removal and fix the hole in it,but before i sell anything i need to do a vin check and the trim tag info...i planned on keeping the boxed rear arms and sway bar for my car..it was close to dark when i got home.tomorrow ill be able to drive it and look at it closer..
Old Nov 28, 2009 | 11:16 AM
heres the vin and trim tag info..i didnt see anything to lead me to believe this is a 442.. it does have the "U" in the vin telling me its a factory 455 car..otherwise nothing special unless you guys know somethng i dont..if ya do enlighten me...its otherwise gonna get cut up...
3g87u2zxxxxx
st 7233687 z 021127
tr 940 a52 65 65
11c 04115 0 650262
Old Nov 28, 2009 | 12:56 PM
2blu442's Avatar
A couple thoughts, have you compared the vin number on the engine to the one on the dash? If it's a replacement motor, did the guy you bought it from know the story on the engine he replaced? In 1972 there wouldn't have been anything to show it's a 442 in the vin. Have you checked to see what kind of emblems were on the car before being painted primer red? From the top picture it looks like a 4 row radiator top plate. That plus the 455, the OAI hood and factory tach doesn't mean it was a 442, but I'd be sure I checked everything before cutting it up, those are nice options for a Cutlass. It also was painted flame orange with a black interior, a pretty sharp car when it was new. My thoughts, check it out real well before stripping it, you may just want to fix it or keep the motor/transmission and sell the rest to someone else to fix. John
Old Nov 28, 2009 | 06:30 PM
Olds luvr's Avatar
Grown Azz Kid
Hello, I sent you a PM
Old Nov 28, 2009 | 06:51 PM
i have not checked the motor vin,it is a vinyl top car.i thought 442s didnt have vinyl tops? shouldnt the trim tag say w-29 if its a 442?haent really looked at the body for the emblems.its a bench seat car.theres a local guru i know i was gonna call him tomorrow and have him come look at it and see what he thought..it wouldnt hurt my feeling at all to remove the motor ,tranny and a few other items for myself and sell the car whole..i just dont yet have enough info to decide what i need to do..
Old Nov 28, 2009 | 08:04 PM
2blu442's Avatar
I'm not an expert with 1972's but I don't think it has to have a W29 on the trim tag to be a 442. If it is the correct motor and or transmission (both have a vin number stamped in them) you might be better off to restore this one. Or at a minimum sell it as a project car and take the profit to buy/build another engine. I have a 1967 and 68 442's that came with bench seats so that wouldn't surprize me. They way I keyed out your trim tag I don't believe it came from the factory with a vinyl top. But I also believe vinyl tops were options on 442's. John
Old Nov 29, 2009 | 10:54 AM
the motor is original for the car....
Old Nov 29, 2009 | 11:04 AM
2blu442's Avatar
"the motor is original for the car...."
Cool! Well, do you have an idea what it would take to save that car? Any evidence what kind of emblem holes were covered over with body filler? When you pick up an old car you never know what your giong to find
John
Old Nov 29, 2009 | 12:12 PM
this car definately had the chrome on the side..holes for cutlass emblem on both front fenders,chrome holes on front part of rear qtrs.and on the doors..did 442s have chrome on the sides?
Old Nov 29, 2009 | 02:23 PM
Yup, some of them sure did. Don't forget that 442 in 1972 was simply an option with upgraded engine, suspension and appearance. There were plenty of cars that came with body side moldingsm=, wheel opening moldings, and the rocker moldings as well. If you had a vinyl roof from the factory, also look for body piercing by the rear 1/4 window and the rear window. (a sure source of water entry over time) Those moldings were held on with speed nuts from inside the sail panel.
Old Dec 1, 2009 | 05:04 PM
im gonna part it...i believe after looking at the body closely,it has cutlass emblem holes in both front fenders a trunklid,and glovebox door..im pretty confident it isnt a 442..rear bumper isnt the cutout one..doesnt look to me like its ever been off. so it goes under the sawzall very soon,ill list parts for sale as i get around to removing them...may be awhile as its more important to me right now to move forward on my car.
Old Dec 2, 2009 | 06:17 AM
Cool car.
Old Dec 6, 2009 | 07:38 AM
vette442's Avatar
This is how people get confused... NONE of the 1970-72 442s had factory side body moldings down the middle like an S or Supreme. They did have trim around the wheelwells, drip rails and vinyl tops, but not on the sides. W29 cars had the thin triple pinstriping, which are in almost the same location down the sides that the moldings would be. No lower rocker stainless either.
Leadfoot, your car was code 65 Flame Orange with a painted Flame Orange top. A52 indicates a bench seat. 1972 W29 cars never had the W29 code stamped on the trim tag either. If they did, it would save a lot of agonizing among '72 owners who don't have build seets with that code on it (and it would weed out a lot of clones too).
Terry
Old Dec 6, 2009 | 10:57 AM
Terry
Thanks for the clarification Terry. Went and looked at my dealer guide and photos. You're right of course. Where it gets a little confusing is when the dealer ordering says you can get ANY Cutlass, Cutlass S or Supreme with one of the 3 442 packages available in 1972. Side rails and rocker stainless were standard on those models, so my reference was based on that. I've also seen 70-72 442's with some of the stainless that you state it should not have. I imagine that a special order could also include part of one package and delete part of another. Makes no sense to me, but there wasn't a lot to be said for standardization in the 60's and 70's. So I guess a "true factory 442" wouldn't have these, but someone who did a dealer upgrade might? I would agree that the car would not be "born" as a 442, but would adding the options and badging by a dealer constitute conversion to a 442? I used to work with dealerships back in the late 70's and it was common practice to "doll up" a car cosmetically to make it more saleable. Inventory turnaround for a dealer is $$.
BTW thanks for the A52 ref. It's on my cowl tag too, but not in the SPECS book. Do you know why this would be put on the cowl tag? The car has certainly got more than that for options which were not standard equipment for that model.
Old Jun 23, 2014 | 08:08 PM
my72olds's Avatar
I'd be interested in boxed lowers and th sway bar, also the hood , and gauges pm me please
Old Jun 23, 2014 | 09:33 PM
2blu442's Avatar
Sorry, but this thread is from 2009. I met Leadfoot once but haven't seen him post in a while.
I'd encourage you to create a parts wanted thread and see what gets offered up.
John
Old Jun 23, 2014 | 10:04 PM
my72olds's Avatar
I did in parts wanted , I did find a guy on here with 4spoke steering wheel all mounting hard wear just missing horn button I'm waiting to receive it now.... Thank you though
iknow
Ninety-Eight
Jun 28, 2010 08:12 PM
69Rman
Jun 14, 2010 06:51 AM
lshlsh2
Apr 27, 2010 12:25 PM
ziff396
Mar 17, 2010 05:34 AM
HAFROD
Apr 6, 2008 06:47 PM
