Fuel guage won’t move
Hi everyone my 65 cutlass fuel guage quit working, It seems to be stuck at 1/2 when it ran out of gas .I checked it by first taking wire off of sending unit and grounding it. checked guage with key on still stuck at 1/2 . Checked again by adding another ground to sender. No change. Makes no difference what I do this guage isn’t moving. What do I do next?
To check the guage for power would that be the 2 studs that go through the circuit board? Also is 0-90 ohms correct for 65 sending unit? I saw 0-30 ohms on some other post regarding sending unit. Can I check the sending unit ohms with the wire off? thanks again.
I tested for ground at the guage it was good on one post so I ran a jump wire from fuse box to the other post then took a look at the guage, it went from 1/2 to E . At least it moved. I’m going to put some gas in and see if it’s working again.
will let you know........
Put in $30 gas no change on guage, came home and connected jump wire from fuse box to guage again, turn on key
guage goes to a little over half. I’m at the conclusion my sender is good but the guage isn’t getting power from the circuit board. If I just connect a wire to the post it should fix the guage to working condition again. Thanks for the advice
This car has no light for the brake. I have Stewart Warner oil and temp gauges so no sensors on motor. Gen light I took out the bulb because it was annoying me and the charging system is working but couldn’t figure out why light stays on.
but that’s another story.
Not saying the bulb itself has anything to do with it, I was saying basically its an old car and if you disturb things in an area it may create bad connections. Also if your fuse block has corroded fuse mounting tabs you may very well have voltage on both sides of the fuse but not on the load side tab itself. Sometimes cleaning or simply removing and reinstalling the fuse will fix that. I've provided as much info to you as I can, your going to have to find where you lost power to the gauge. Once you restore power you can simply remove the wire at the sender with the key on and the gauge needle will go past F. If you ground that wire it will drive the gauge needle to E. If it does this then all of the gauge wiring and the gauge is operating correctly.
Yeah it is 54 years old, I’ve already cleaned all the fuse connections, the circuit board isn’t the greatest 1 post is loose and I think one is missing but I had traced it down to hi beam light when I had the dash apart. The fuel guage was about the only thing that did work when I got this car . I didn’t disturb the circuit board other than cleaning. I’m thinking the circuit board is bad. Thank you so much for your help. I can usually figure things out for myself but I’m a mechanic machinist and not strong on electrical stuff especially things like this that usually don’t go wrong .
