engine change
Old Apr 20, 2007 | 06:15 PM
upstater_12883's Avatar
engine change
I have an 86 cutlass salon with a knockin 350r. I was given a buick 430 and need to know if it will bolt right in or do i have to change the motor mounts?
Old Apr 21, 2007 | 11:14 PM
Originally Posted by upstater_12883
I have an 86 cutlass sapon with a knockin 350r. I was given a buick 430 and need to know if it will bolt right in or do i have to change the motor mounts?
Motor mounts, accessory brackets, wiring...
Old Apr 27, 2007 | 03:12 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. You may want to measure the width of the valve covers of the two, and compare for fit. I'm not sure on the Buick's starter, and fuel pump lacations. You might want to compare those as well. Best of luck.
Old Apr 27, 2007 | 04:16 PM
68/70 Cutlass's Avatar
Is the 350 Olds? If so you can retain the trans. The changing will be mounts, exhaust, wiring and on and on like Joe was saying. The 430 is a 60's engine and heavvvvy so different springs in the front suspension too I would think
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
oldjunk
May 10, 2009 06:30 AM
delta881972
Jan 2, 2009 06:54 AM
jdorour
Sep 29, 2005 06:50 AM
