Distributor plastic guide and o-ring
Old Oct 13, 2014 | 11:56 PM
Winger67's Avatar
1972 Cutlass Convertible
1972 Cutlass 350. Decided to install a Pertronix Igniter III and after attempting to install the new grommet with it in the car I decided it'd be easier to get the distributor out of the car. I ended up breaking this plastic guide from the baseplate. Is it really needed? I assume it just keeps the wires away from the cam. Also broke the ground wire than ran from the vacuum advance screw to the baseplate. Can I just attach an spade terminal and use one of the points screws on the baseplate?
Is there an o-ring I need to replace? It looked like there was some sort of band on the distributor shaft but it looked pretty flat and was hard. I guess it could be just from age.
Old Oct 14, 2014 | 02:52 AM
I can't say much about that nylon guide, other than that I've never seen one, which to me would indicate that they are both fragile and non-essential.
The ground wire is essential, and should be the same type of very thin, very flexible wire, or your car may stall intermittently.
BWD DL77 and AC-Delco C1203 are exact replacements.
The O-Ring is a standard part and should be available at any auto parts store. It's FelPro 424.
Old Oct 14, 2014 | 04:01 AM
Winger67's Avatar
Thanks!
Old Oct 14, 2014 | 04:38 AM
tru-blue 442's Avatar
Old School Olds
That nylon guide holds a small piece of felt that wipes the cam
with grease if I remember right.
Old Oct 14, 2014 | 04:50 AM
Winger67's Avatar
Ahh. Seeing as the Igniter III doesn't make contact I assume it's not needed any more.
Old Oct 14, 2014 | 06:17 AM
mrolds69's Avatar
Tru-blue 442 is right, there was a foam doughnut that went over the plastic piece to lube the cam. It was a replacable part that disintegrated over time.
Old Oct 14, 2014 | 06:32 AM
RandyS's Avatar
You are correct.
c-towndave
Dec 2, 2014 07:43 PM
oldspackrat
Aug 10, 2014 10:03 PM
costpenn
Apr 20, 2014 06:25 AM
BradyB
Sep 20, 2012 11:11 AM
JerseyHarold
Dec 14, 2010 05:13 PM
