Distributor Cam Lubricator
Just getting around to replacing the points in my 72 350 and noticed the distributor cam lubricator is completely worn out...does anybody still sell these? If not, what can I use as a replacement? I noticed there was some lube that came with my new points...can I just lube the bumper on the point set and forget about the cam lubricator? Just trying to do what the good book (i.e Service Manual) suggests......Thanks!!
You are referring to the little felt block, correct? Gee I don't know where you could purchase that new as a separate item but are there any junk yards in your neighborhood? Every GM distributor I know of used one of those, shouldn't be hard to scavenge one from someplace.
Of course, this may be nature's way of telling you it's time to go electronic...
Just checking around...seems like its going to be hard to replace. My point set came with a capsule of grease so I guess I'll use that on the cam itself and the rubbing block on the points. It's not like the car is my daily driver anyway so I'm thinking I can get by without replacing the lubricator which is just a little plastic piece that I assume held lube at some point. Thanks!
lyev
June 14th, 2015 04:08 PM
chris83
August 18th, 2012 01:47 PM
