Cutlass Frame Questions
Old Mar 18, 2009 | 10:18 AM
grt05's Avatar
Hi All,
I'm new to this forum and I have a question about my '69 Hurst/Olds. What year frames will be a direct replacement? I've read '67 to '72 A-body frames will work, but should I really just search for a '69 Cutlass? Any help would be appreciated.
Thanks,
Mike
Old Mar 18, 2009 | 11:19 AM
Originally Posted by grt05
Hi All,
Thanks,
Mike
All 1968-1972 A-body 2dr HT or sport coupe (post car) frames will interchange. That means Chevelle, LeMans, and Skylark in addition to Cutlass. The 69-72 Grand Prix and 70-72 Monte Carlo are also A-body cars but these two use a unique frame with a different wheelbase. The 64-67 cars use a slightly narrower frame with a longer wheelbase (115" vs. 112").
Old Mar 18, 2009 | 01:34 PM
grt05's Avatar
Thanks for the reply. Excuse me if my questions seem ignorant, but I am new to this. Doesn't small/big block make a difference? Would there be small differences between the models such as mounting holes or tabs or something like that?
Old Mar 18, 2009 | 01:53 PM
68Tom's Avatar
They'll interchange, however, I'm fairly sure the '68 frame is a one-year only frame. Think it's different for '69. It fits, but they're different. At least this is what I was told when I discovered mine was full of holes and cracked.
The frame for BB/SM doesn't matter. However, Olds used different engine mounts for BB or SB.
Old Mar 18, 2009 | 05:55 PM
68-72 will all interchange. All A-body frames are drilled for all the different divisions motor mounts. All 68-72 A-body frames have both sets of crossmember holes pre-drilled.
Once again ONLY for 1969-1972 and either BBO or SBO brackets can be used with either BBO or SBO, so long as the matching rubber motor mounts are also used. In any case, they bolt to the same bolt holes in the frame.
Old Mar 18, 2009 | 06:44 PM
Cameo White's Avatar
Smile
Welcome Mike.
There are a few of us with 69 H/O's on the forum. Post pics when you can.
Old Mar 19, 2009 | 02:31 AM
Yellowstatue's Avatar
Smile Frame
On a '68 frame the pass through hole for the rear brake flex line is almost in the centre of the crossmember and on '69 the hole was moved 10 or 12 inches outboard...
Old Mar 19, 2009 | 05:04 AM
grt05's Avatar
Thanks for all your replies. Now I can start looking for a new frame. Once I get the car out of storage I'll post some pics.
Mike
Old Feb 3, 2018 | 11:05 AM
Carsick's Avatar
69 442 frame interchangability
I need a frame for my 1969 442 ht sc. Will a 67 chevelle frame work? Im thinking it wont but hoping it will
Old Feb 3, 2018 | 12:19 PM
Scroll back up and read post #2. The 1964-67 A-body frames are narrower and use a 115" wheelbase. A 1969 442 uses a 112" wheel base.
coppercutlass
Body work
Mar 25, 2014 05:40 AM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
