Cutlass automatic gear "lags"
Old Sep 5, 2007 | 12:21 PM
Oldsmofjord's Avatar
hey
so I was driving around the other day and suddenly the car could not change its gear and it just sounded "harsh" whenever I pressed the pedal
This only happens when I have it in "D" - it works fine in Reverse, 2nd and 1st gear.
Old Sep 5, 2007 | 09:50 PM
The_Jeremiah's Avatar
lol i dont know what "harsh" means, but if its been awhile since you have changed your tranny filter and fluid, that would be a good idea to start with. and if that doesnt fix it, it could be a bad synchro in 3rd gear. dont know for sure, you should definently try your best to not drive it while its acting up though, because doing that can make a 5 dollar problem turn into a 500 dollar problem. good luck
Old Sep 6, 2007 | 12:24 AM
I do have a problem explaining a problem in English
The workshop changed fluid and filter 2 months ago. The car's been running like a rocket since. Then suddenly it stumbles. The workshop adjusted the gearwire and it worked like a charm for 3 days. Then suddenly the trouble started again. Only this time, it comes and goes ! Feels like the trouble starts when I've driven a bit and the car is hot.....
Old Sep 12, 2007 | 01:52 PM
it does not change gear from the 2nd to the 3rd - it "jumps" straight to 4th gear....what can be here the problem ?
Old Sep 12, 2007 | 08:28 PM
marcar1993's Avatar
3rd gear is slipping. Get ready for a complete trans rebuild most likely.
Old Sep 13, 2007 | 12:17 AM
noooooooo
Old Sep 13, 2007 | 05:08 AM
Oldsguy's Avatar
Past Administrator
Yes, I agree that is sounds like time for a rebuild. Sorry,,,
Old Sep 17, 2007 | 03:17 AM
what type of gearbox is in my car ? TH-200 or TH-700 ?
It's the Olds Cutlass 1981 sedan, with V6 and 231 Cid.....
mcutlass1969
Jan 4, 2013 04:20 PM
drjr56
Sep 9, 2012 08:05 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
ztim
Apr 20, 2008 11:12 AM
