Core support for 1971 Cutlass S
Mine has a lot of rot....Been trying to track down a repop core support but 71 seems to a year that is not reproduced often? Is there an interchangeable year I can use? Any help is appreciated.
Okay, well that makes it easy enough I guess. I see OPGI has a repop for a 1970. This will work correct?
https://www.opgi.com/cutlass/C241184/
the core supports are for that year only as joe pointed out, he mentioned 72 can be used on 71 and vice versa but if you use a 71 on a 72 you have to use the 71 grills
depnding on condition many folks will repair theirs
so no the 70 will not work on your 71
