Core support for 1971 Cutlass S
Old Jun 25, 2018 | 06:13 AM
72cuttys's Avatar
Mine has a lot of rot....Been trying to track down a repop core support but 71 seems to a year that is not reproduced often? Is there an interchangeable year I can use? Any help is appreciated.
Old Jun 25, 2018 | 06:46 AM
Core supports are one-year-only from 1964-1972. The 1972 support can be used on a 1971, but it will not be correct.
Old Jun 25, 2018 | 08:02 AM
72cuttys's Avatar
Okay, well that makes it easy enough I guess. I see OPGI has a repop for a 1970. This will work correct?
https://www.opgi.com/cutlass/C241184/
Old Jun 25, 2018 | 08:04 AM
Did you read post #2???
Old Jun 25, 2018 | 01:50 PM
RetroRanger's Avatar
72 Olds CS
the core supports are for that year only as joe pointed out, he mentioned 72 can be used on 71 and vice versa but if you use a 71 on a 72 you have to use the 71 grills
depnding on condition many folks will repair theirs
so no the 70 will not work on your 71
code26
Jun 4, 2018 08:21 PM
george landis
Body work
Mar 2, 2017 05:11 PM
geoff442
Dec 6, 2016 03:00 AM
AK71CutlassS
Feb 22, 2016 03:45 PM
dhoff
Body work
Apr 23, 2010 07:01 AM
