cooling hose
Old Mar 14, 2008 | 09:47 PM
projectheaven's Avatar
cooling hose
Hello all,
Does anyone have any suggestions on what I can use for the 3/4 hose that goes from the thermastat housing to the water pump? I bought a chrome housing and it doesnt have the metal tube.
Old Mar 15, 2008 | 06:33 AM
Eighttime's Avatar
Oldsmobile Asylum
Is it also missing the hole, where the by-pass neck should be?
Old Mar 15, 2008 | 09:23 AM
rocketraider's Avatar
Oldsdruid
Ask the parts store for a bypass hose for a 1965-67 425 engine. Those didn't have the curved metal tube; they had a molded curved hose instead. The change was made in the late 60s since apparently a curved metal tube was cheaper to make than a curved molded hose.
A good (read accommodating) parts store will let you ramble thru their molded hose stock and match up something.
I expect this chrome t-stat housing will give you leak problems. I've never seen one that didn't. You need to sand the sealing surface on a piece of plate glass or known flat metal plate to true it. Expect to use a lot of sealer even then.
Old Mar 15, 2008 | 10:21 AM
The chrome housing has the bypass hole.Rocket raider gave good advise.I'll definitely look and call some auto parts stores today.
Sampson
Mar 24, 2015 09:33 AM
68conv455
May 12, 2008 05:29 PM
stevefree04
Jan 8, 2007 07:00 PM
ztim
Dec 22, 2006 12:44 PM
davy5
Nov 30, 2006 10:16 AM
