Combo valve relocate and 455 headers
Old Feb 6, 2020 | 03:18 PM
highschoololds's Avatar
So, what’s the general procedure for relocating? Will it require new lines, custom made, etc?
Just thought I might pick someone’s brain with firsthand experience.
Old Feb 6, 2020 | 06:11 PM
If you have an automatic, I've been able to move the combo valve to the top of the frame rail using one of the pre-drilled holes where the bracket for the clutch equalizer goes on MT cars. I was able to do this by hand-bending the existing lines without disconnecting them. Obviously this won't work on a car with a clutch.
Old Feb 6, 2020 | 06:15 PM
It is an auto.
Might these be said holes? Where frame turns down to go under firewall. Directly under master cylinder.
Old Feb 6, 2020 | 06:22 PM
Originally Posted by highschoololds
It is an auto.
Yes. You'll only be able to pick up one of them, but that's enough.
Old Feb 6, 2020 | 06:23 PM
Many thanks.
QS442
Oct 16, 2019 02:17 PM
rpinnt
Jul 20, 2018 11:09 PM
dre
Jul 3, 2012 09:50 AM
Gearhead442
Apr 8, 2010 06:30 PM
