Flow Tech 455 headers
Old Jul 2, 2012 | 03:25 PM
dre's Avatar
dre
Has anyone had any clearance issues with Flowtech headers on a 455? My headers are in, but I've noticed I've had some clearance issue with the proportioning valve. Any suggestions would be greatly appreciated.
Old Jul 2, 2012 | 03:29 PM
cutlassefi's Avatar
No but the set I just used on the dyno was a bit pidgeon toed at the collectors, caused a problem hooking up the dyno exhaust system.
Old Jul 2, 2012 | 04:32 PM
Qwik71442's Avatar
Full-time Taxpayer
You will need to move the proportioning valve from the inside of the frame to the top of the frame with the flowtechs assuming this is a 68-72 A-Body
Old Jul 2, 2012 | 04:34 PM
You have to reroute some of your brake lines and relocate the proportioning valve away from the headers. Possibly a little dimple here and there. Most have trouble around the upper A frame mounting area on the passenger side.
Old Jul 2, 2012 | 07:33 PM
dre's Avatar
dre
Would you happen to have a pic for visualization?
Old Jul 3, 2012 | 08:14 AM
dre's Avatar
dre
What are good 455 headers to use in order to have the clearance needed for the proportionung valve without having to make modifications?
Old Jul 3, 2012 | 08:42 AM
dc2x4drvr's Avatar
I think most aftermarket headers in Olds A bodies require the valve to be moved.
Old Jul 3, 2012 | 09:02 AM
x2
Old Jul 3, 2012 | 09:50 AM
archeryshooter's Avatar
Tony
I just put my motor in and I used Dougs headers and was very impressed they are not cheap but well worth it all the bolts screwed in easily and they cleared everything and 3/8 flanges to with NO leaks I have used cheaper headers in the past and never did like them.
scooter123
Mar 2, 2013 07:32 AM
VORTECPRO
Sep 15, 2012 05:29 PM
MHENDERSON
Jan 6, 2011 05:23 PM
agtw31
Jul 12, 2009 09:51 AM
Oldsguy
Apr 24, 2006 07:43 AM
