Changing the front Springs in my 76
Just wondering how to go about changing the springs in my 76 cutlass "S". I just dont see what angle to tackel this from. Will there be enough room if i drop that arm? Im also guessing i will need to find a spring compresser. Any help with this would be much appreciated. I am not much of a mechanic. Thanks
You need to use a hydraulic jack and bring the lower control arm down slowly. Be very careful doing this. Don't forget to remove the shock. Good luck. I usually get my springs banded for the fronts. Makes it easier to install.
Thanks. I have contacted a local store about renting some compressers. We just took out one of the springs by droping the arm and braking the old spring free with a hammer then carefully slipping out the old spring. These new springs are stiff as hell. compresser tommorow for sure. Thanks for all the help guys.
Alex72cutty
Suspension & Handling
22
April 15th, 2015 10:59 PM
MyPaceCar
April 22nd, 2012 07:13 PM
Texas442
March 5th, 2011 10:20 AM
