Changing the front Springs in my 76
Old May 30, 2007 | 03:46 PM
Devon76's Avatar
Just wondering how to go about changing the springs in my 76 cutlass "S". I just dont see what angle to tackel this from. Will there be enough room if i drop that arm? Im also guessing i will need to find a spring compresser. Any help with this would be much appreciated. I am not much of a mechanic. Thanks
Old May 30, 2007 | 04:02 PM
crazy'boutOlds's Avatar
You need to use a hydraulic jack and bring the lower control arm down slowly. Be very careful doing this. Don't forget to remove the shock. Good luck. I usually get my springs banded for the fronts. Makes it easier to install.
Old May 31, 2007 | 06:11 AM
Jokers69's Avatar
Senior Moment
There's a fair amount of hazard in the stored energy in the spring, you should get spring compressers. If you have the $$ it would be better to have a front end shop do it, your going to need an alignment either way.
Old May 31, 2007 | 05:50 PM
Devon76's Avatar
Thanks. I have contacted a local store about renting some compressers. We just took out one of the springs by droping the arm and braking the old spring free with a hammer then carefully slipping out the old spring. These new springs are stiff as hell. compresser tommorow for sure. Thanks for all the help guys.
Alex72cutty
Suspension & Handling
22
Apr 15, 2015 10:59 PM
66olds98conv
Ninety-Eight
May 14, 2013 06:57 PM
MyPaceCar
Apr 22, 2012 07:13 PM
Texas442
Mar 5, 2011 10:20 AM
72Cutlass
Apr 12, 2008 07:54 PM
