Cannot Remove Power Steering Pump Pulley
Old Jul 12, 2025 | 05:55 PM
rbt111's Avatar
Hello everyone. My PS pump went out on my '66 Cutlass. I could not loosen the nut that holds the pulley on as it just spins away even with a 1" wrench on the pulley. I had to remove the whole bracket to get the pump out of the car and on my workbench. Tried using an impact when I had it on the workbench but still the same result. Other than breaking out my bandsaw which is my next step is there some way to prevent the shaft from spinning so I can separate the pulley from the pump?
Thank you.
Old Jul 13, 2025 | 08:28 AM
Bolt the pump back on the engine, reinstall and tension the belt. NOW try to loosen the nut.
Old Jul 13, 2025 | 09:13 AM
Loaded68W34's Avatar
Are you saying that the shaft and pulley are spinning together when you try to loosen the nut, or is the shaft spinning in the pulley?
Old Jul 13, 2025 | 10:20 AM
The pulley has a key, though that goofy washer says that the pump has been apart before.
Old Jul 13, 2025 | 12:12 PM
rbt111's Avatar
Yes, the woodruff key was the source of the problem. I was able to get the pulley off by basically putting the the pump in a head lock and muscling it at an angle against the work bench with one hand and using an electric impact on the nut with the other. Upon inspection I could see the woodruff looked as if it got sheared. $15 at Advance Auto for the keys and a quart of ATF and shes all back together now minus the goofy nut. After bleeding the air out the front wheels move with ease again.
Yes, the woodruff key was the source of the problem. I was able to get the pulley off by basically putting the the pump in a head lock and muscling it at an angle against the work bench with one hand and using an electric impact on the nut with the other. Upon inspection I could see the woodruff looked as if it got sheared. $15 at Advance Auto for the keys and a quart of ATF and she's all back together now minus the goofy nut. After bleeding the air out the front wheels move with ease again.
Last edited by rbt111; Jul 13, 2025 at 12:17 PM. Reason: wrong word. I meant to say washer not nut
Old Jul 13, 2025 | 12:15 PM
rbt111's Avatar
The pulley was moving independantly of the shaft because of a sheared woodruff key. That's what made it a b!t#h to get the nut off. Holding the pulley with a 1" wrench on the flat part did nothing.
Old Jul 13, 2025 | 12:42 PM
That's what I thought you were saying in your first post. Good job fixing the problem. However, that is a pretty unusual failure.
Old Jul 13, 2025 | 02:31 PM
Definitely a new one on me
Old Jul 13, 2025 | 02:46 PM
66_Jetstar's Avatar
Ripping donuts with the wheel against the stop and the pedal on the floor will do that.
That was a once year job at the shop around the first real snow of the year.Sometimes the belt would jump off, sometimes the shaft would shear right off the pump. Usually it was a kid driving dad's truck in an empty lot.....
jaunty75
Jun 24, 2024 09:14 AM
BSiegPaint
Jan 29, 2024 07:15 AM
MPSax
Jan 28, 2024 06:11 PM
tommyd
Oct 3, 2023 02:24 PM
Will22
Feb 23, 2019 08:55 PM
