a/c question
Old Jun 11, 2008 | 09:15 AM
Big Henry's Avatar
a/c question
my a/c makes cold air but you can only feel it 8-10" from the vent could it be the fan? or compressor? wanted to ask you guys before i went ripping into it because this heat wave is giving me heat stroke!!
Old Jun 11, 2008 | 10:03 AM
Oldsguy's Avatar
Past Administrator
See if you get more forceful air from a different vent in a different mode. If you can then it is the door actuators for the dash that are not opening fully, if you cannot then you may have a bad blower motor or bad resistor block.
Old Jun 11, 2008 | 03:14 PM
Big Henry's Avatar
ok i got the manual now. how do i check if the motor blowers bad? just not working?
Old Jun 11, 2008 | 04:43 PM
Maybe I missed it, but what year and model is this?
Old Jun 11, 2008 | 05:12 PM
Big Henry's Avatar
95' cutlass ceria SL
Old Jun 12, 2008 | 06:36 AM
The first thing I would do is run a temporary jumper wire from the +12V terminal on the battery directly to the power terminal on the motor (be sure you have the power terminal and not the ground terminal). This is the highest speed for the motor and if you now get proper flow, then there's a problem in the switch or the speed control resistor. You should also be able to hear the motor running at full speed. If not, then there is probably a problem with the motor. If the motor runs but there's still no air, you may have a plugged evaporator or you may have a problem with the vacuum actuators for the air doors in the box under the dash.
Old Jun 12, 2008 | 12:55 PM
Oldsguy's Avatar
Past Administrator
Or, the motor may work but the impeller has broken off the shaft. My experience is that most of the impellers are plastic and held in place with a lock washer on the end of the shaft which has a keyway on it.
Old Jun 12, 2008 | 01:50 PM
Yup. I've had that happen too. In my case, however, the loose fan made one heck of a racket.
Old Jun 12, 2008 | 03:24 PM
Forget what everyone else said. They don't know what they are talking about. Your problem is obviously STARVATION!
Yep, that's right. STARVATION!
How long has it been since you fed the squirrle that powers the fan? If he doesn't have any food then how do you expect him to run inside of his cage? I suggest you buy some squirrle food from the pet store and drop it into the air plenum through your uppermost vent. Give it a day or two and see if he gets better. You might want to pour some water down the vent too. Just incase he is thirsty.
Old Jun 13, 2008 | 11:12 AM
Lady72nRob71's Avatar
My squirrel is dead. This explains the foul odor, as well...
I guess I did not see the feeding and watering guidelines in the FM...
Oh well, at least replacements could be had easily in my own yard!
I guess I will need to rig up a nut-injection system to feed him.
The condensate water will automatic as is...
Old Jun 14, 2008 | 09:08 AM
Old Jun 14, 2008 | 03:48 PM
Big Henry's Avatar
this is the blower motor right it looks like just want to make sure
it looks like it from the picture in the manual if so i found that the blower motor cooling tube was completely off so it just might be the motors gone in it i haven't checked it yet i couldn't get it all the way out the damn alternator's in the way.
p.s. i did say a few healing words when i dropped one of the screws to the motor in the grass (found it tho) using sheet next time
Old Jun 15, 2008 | 06:05 AM
You know, Joe mentioned the speed control resistor. I recall Oldsguy and I had to hunt one of those down for his 76 Olds 98 Regency. I think we bought one from the salvage yard and had to exchange it a few times because the ones we were getting were bad as well.
Old Jun 16, 2008 | 12:42 PM
Big Henry's Avatar
well it isn't the blower motor changed it out today a few of the pedals were broke so i went ahead only costed me 32$ but its still not blowing really hard like i think it should and i notice it takes along time for it to get cold....any ideas? also tommorow morning i'm taking the bat test to hopefully become a step closer to being a corrections officer 2,000+$ a month as a trainee =]
yeahbuddy
Dec 19, 2011 08:40 PM
