79 Cutlass with 455
Old Oct 24, 2022 | 11:06 AM
71Cruiser's Avatar
79 Cutlass with 455
Well,
I went ahead with this project, got the 455 rebuilt with mild cam, going in with th400. That's the tip of the iceberg, when I look at it. What to do for accelerator linkage and bracketry? Got essentially nothing, except a rebuilt quadrajet and the accelerator cable coming out of the firewall. Using an Edelbrock intake. Same for transmission shifter bracket - I have a column shifter and want to keep it. Any ideas on what parts to source to make this work?
Thank you!
Tom
Old Oct 24, 2022 | 01:40 PM
I used factory throttle linkage on my car with no problems. Since you have a 400 trans, you don’t need to worry about the correct linkage for the kickdown cable. On my 69, there was plenty of cable length to compensate for the additional height of the performer intake.
Old Oct 24, 2022 | 01:41 PM
I just noticed you have a 79, same thing applies. I have done several G body 455 swaps, i always used the 260/307 throttle bracket and cable.
Old Oct 25, 2022 | 06:57 AM
71Cruiser's Avatar
Hi Matt,
Thanks; unfortunately, my bracket went out with the 260. I will have to locate one. Shouldn't be too hard -- thank you!
Old Oct 25, 2022 | 02:11 PM
maxi426's Avatar
Look at a TCI 376700 for a throttle cable bracket. Looks like an Olds Qjet bracket
Old Oct 25, 2022 | 02:31 PM
CRUZN 66's Avatar
Olds Fever
The standard 260/307 brackets worked for my big block swap in my 85 Cutlass....
Old Oct 26, 2022 | 07:46 AM
71Cruiser's Avatar
Thank you!
JIM'S w30
May 29, 2020 12:41 PM
Keith Jones
Aug 22, 2018 05:31 PM
hotrod
Aug 12, 2013 01:06 AM
gearhead1218
Jul 19, 2013 10:41 AM
Gixxere
Aug 23, 2011 10:27 AM
