78 Calais new engine question
My poor Calais, so pretty on the outside, just died on the inside. It has the original 2bbl 231 Buick V6. Do I understand correctly that if I want to put a V8 in, I will have to have to weld in new motor mounts put in?
Or, should I try to keep it cheap and slow with V6 swap?![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Thanks for any advice!
My suggestion would be to grab the mounts and a wiring harness from a 78 to early 80 A body that came with a 260 because that is where you'll find the correct frame mounts and wiring so you don't have to hack up yours to make it all work. I don't know that anyone is reproducing the harnesses for your era car....yet.
usa2449
February 21st, 2017 02:58 PM
JCMC64
March 26th, 2013 05:53 AM
