78 Calais new engine question
Old Sep 21, 2013 | 04:57 PM
Dissector's Avatar
My poor Calais, so pretty on the outside, just died on the inside. It has the original 2bbl 231 Buick V6. Do I understand correctly that if I want to put a V8 in, I will have to have to weld in new motor mounts put in?
Or, should I try to keep it cheap and slow with V6 swap?
Thanks for any advice!
Old Sep 22, 2013 | 06:22 AM
Every brand of GM motor uses different frame mounts. If you want to put an Olds motor in place of your Buick V6, yes you need to change the frame mounts. These bolt in, however. No welding is required. The frame mounts for Olds V8s are the same on all 1978-1988 A/G body cars and also on all 1977-1990 RWD B?C body cars, so they are pretty common. Once you get the correct frame mounts, use Anchor P/N 2328 motor mounts to install the motor.
Old Sep 22, 2013 | 06:43 AM
Dissector's Avatar
Great info, thanks. And frame mounts is exactly what I was referring to. Now the quest is on for a new engine....
Old Sep 22, 2013 | 08:21 AM
The mounts you want look like this. Note that they are different RH/LH.
Old Sep 22, 2013 | 08:54 AM
Dissector's Avatar
Fantastic! Guess I'll be on the lookout for those too!
Thanks again!
Old Sep 22, 2013 | 09:35 AM
svnt442's Avatar
My suggestion would be to grab the mounts and a wiring harness from a 78 to early 80 A body that came with a 260 because that is where you'll find the correct frame mounts and wiring so you don't have to hack up yours to make it all work. I don't know that anyone is reproducing the harnesses for your era car....yet.
Hark442
Nov 4, 2018 06:39 PM
usa2449
Feb 21, 2017 02:58 PM
Kyle's 77 Cutlass
Nov 1, 2014 05:57 PM
<Tim>
Jun 21, 2004 12:29 AM
