71 CS, How to remove trim for vinyl.
Old Nov 13, 2020 | 10:54 AM
Miles71's Avatar
I have a 71 CS with a Vinyl top?
I figured out a few parts on the rear deck. But not sure how to remove the other sections.
https://classicoldsmobile.com/forums...e-trim-150332/
Old Nov 13, 2020 | 04:12 PM
1970supremevert's Avatar
these clips hold the halo trim, these should be the same as the rear deck section ,I use the plastic putty knife to get it started or if you have a trim tool , just go slow so you don't bend the trim
Old Nov 14, 2020 | 05:58 PM
Miles71's Avatar
Thanks for the tips to remove the trim.
There are two types of clips, I'll just call them A and B.
The B-clip has a screw hole mount. There are 8 of these.
The B-Clips were much harder to Pop off and usually shattered.
The A-Clips slide over an existing stud. These popped off easily.
I plan on buying a few new of each for the re-installation.
I did use a pair of plastic putty knives to slide under the trim and pop off.
Front section with trim removed
The Screw clips were harder to pop off. The key-hole style popped off easily.
Body work
May 14, 2019 05:06 AM
midnightleadfoot
Mar 27, 2018 08:57 AM
John Hancock
Tech Editor's Desk
Dec 19, 2011 06:53 AM
oldzzy
Jun 23, 2011 07:24 PM
krgentrup
May 28, 2010 10:30 AM
