68 Cutlass
Old May 10, 2012 | 10:02 AM
occph's Avatar
68 Cutlass
What is the difference between a Cutlass and Cutlass S in 68, because looking for parts you can get it for one but not the other?
Old May 10, 2012 | 10:29 AM
1971Cutlass's Avatar
In Recovery Mode
I
think S stands for Sport
2 door or four door
Old May 10, 2012 | 10:32 AM
occph's Avatar
it is a 2 door convertable with a 350 4bbl
Old May 10, 2012 | 10:52 AM
dephconn24's Avatar
post some pictures if you can
Old May 10, 2012 | 11:05 AM
boese1978's Avatar
Base model is the F-85, with mid-level Cutlass S, and upscale Cutlass Supreme, as well as the 442 in 1968
Old May 10, 2012 | 11:06 AM
occph's Avatar
Can't at work till the morning. just want to know why is it so hard to get parts for the 68 Cutlass S
Old May 10, 2012 | 11:13 AM
boese1978's Avatar
Parts should be interchangable.
Old May 10, 2012 | 11:17 AM
occph's Avatar
Thanks,
tried to get high lift coil springs and they stated that it fit the Cutlass but not the Cutlass S
Old May 10, 2012 | 11:37 AM
allyolds68's Avatar
You could only get a convertible in a Cutlass S or 442 trim in 68 and they were very similar. The springs were different depending on engine type, towing package, etc. Get 442 springs they were the same whether convertible or Hardtop. Here's the page out of the assembly manual:
Old May 10, 2012 | 11:42 AM
occph's Avatar
i will do that thank you
Old May 12, 2012 | 12:35 PM
Originally Posted by 1971Cutlass
I
2 door or four door
The "S" stands for S. There was no "Sport" model. It's just a name made up by the marketing department. There are no substantive mechanical differences between a Cutlass, Cutlass S, or Cutlass Supreme, just trim and base equipment differences.
