68-72 A body Jack Question
Old Aug 27, 2009 | 04:59 PM
sklbndt's Avatar
Does anyone know what year Cutlass's utilize the same jacks? Thanks!
Old Aug 27, 2009 | 07:31 PM
70Post's Avatar
I am pretty sure the 70-72s are the same physically.
Not sure about earlier. And some cars seemed to come with the solid "T" post type jacks while others had the tubular style shaft. I think by '71, if not by 1970, they all had the tube style shafts.
Old Aug 28, 2009 | 01:47 AM
Alb's Avatar
Alb
jacks
I think the 68-69 are the same also.
Alb
Old Aug 28, 2009 | 02:22 AM
Yellowstatue's Avatar
Thumbs up Need a lift?
The '74 parts book reads Jack, auto /less load rest base PN230769 1968-72 all except wagons ...
PN230662 1968-72 all wagons: My '68 came with a Y post jack Under jack base they list PN39068 1967-68 all US w/1.160 square mast & '69 except wagons. 1970 all with square mast...PN 230775 1968-70 all except wagons AY type: PN3995122 1971-72all-for V shaped shaft w/universal column...so your car could have come with a variety of jacks depending on the jack supplier...
Old Aug 28, 2009 | 04:14 AM
jack
Since we're on the subject.
I have seen them in black and grey. I was told it depended on which assembly plant they came from.
Old Aug 28, 2009 | 04:52 AM
sklbndt's Avatar
Holy Crap Not really knowing one from another I'd need a degree to decify all that. Basically I have a 70 jack and am wondering if it will work on the 68 vert I bought that didn't come with a jack. I guess I need to get the part numbers off of it and try and decipher things.
I have a parts book on CD but couldn't find the jack....what group is it in.
Old Aug 28, 2009 | 05:14 AM
Lady72nRob71's Avatar
I would not doubt that. I have also heard that about other parts such as chassis parts...
Lady has a black jack...
Old Aug 29, 2009 | 01:38 AM
mugzilla's Avatar
is Fast Enough ...
I use a hyd jack espacially when I get my bumpers back ...
Old Aug 29, 2009 | 02:36 AM
Smile Group hug
The jacks are in group 8.820... and speaking of jacks, as Mugzilla says, I too use a hydraulic jack for my '57 and those eighties GM jacks that lift the frame near the wheels for the Cutlass dept....the bumper jack is only for show...
Old Aug 29, 2009 | 03:05 AM
This is very true. Oldsguy and I put a small hydraulic floor jack in our trunk just in case there is car trouble. Bumper jacks are bad news.
Old Jan 2, 2010 | 05:16 PM
oldoldss's Avatar
I got a flat on the Ohio Turnpike coming home from Homecoming in 1998 and had to use the original jack to change the tire (fortunately it wasn't still the original spare tire). What a scary, shaky operation! Bumper jacks are for show only!
Old Jan 27, 2010 | 11:35 AM
RATCHETMASTER's Avatar
"I reckon so!"
My 1969 442 jack says 68-69 on it. I can't remember if it says A-body or Cutlass on it. I will try to look at it when i get home.
edit: I think it says F85 on it.
Old Jan 27, 2010 | 09:50 PM
tomsw31's Avatar
The 1970 cutlass jack set up will work on your 1968 Cutlass. The lift or hook part should have the number 406925 stamped on it if it came out of a 1970 Cutlass or 442. As stated above, if you actually use it, expect the bumper fillers to be pushed into the front fenders and possibly chip your paint.
Old Apr 9, 2010 | 06:15 PM
rallygreen's Avatar
68-69 bumper jack
i have one and it says 68-69 f-85 stamped on it! let me know if you need thanks!
rcktdoc
Jan 26, 2016 05:02 AM
costpenn
Jul 1, 2014 02:33 PM
NDERISE
Mar 10, 2013 09:23 PM
OldsMotion
Oct 10, 2009 10:17 PM
kaz442
Nov 26, 2008 02:43 PM
