67 cutlass engine id.
Old Apr 16, 2013 | 01:53 PM
pbarney's Avatar
I have a 67 cutlass s and I want to make sure it has the 330 v-8 it's suppose to have. The right head id boss has been milled smooth but there are 2 charactors stamped on it-the numbrer one then a dash. The numbers on the timing chain housing are 3944173. Are there other way I can verify the engine?
Old Apr 16, 2013 | 05:55 PM
Run to Rund's Avatar
Sometimes the engine sequence number will be on the driver's side head pad, which faces the firewall.
Old Apr 16, 2013 | 06:11 PM
Oldsmaniac's Avatar
Not a positive ID but the 67 330 heads should have a number 4 cast just to the left of number 1 spark plug hole.
Old Apr 16, 2013 | 06:36 PM
+1 on Run's comment - when people take the heads off, they don't care which side they put them back on.
Old Apr 17, 2013 | 07:44 AM
pbarney's Avatar
Thanks so much you guys. My heads apparently were removed and switched so the #'s were aginst the fire wall. I learned I have the proper engine and the heads were removed sometime in last 46 years. I am grateful
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
pinky
Oct 1, 2007 11:24 AM
