67 cutlass engine id.
I have a 67 cutlass s and I want to make sure it has the 330 v-8 it's suppose to have. The right head id boss has been milled smooth but there are 2 charactors stamped on it-the numbrer one then a dash. The numbers on the timing chain housing are 3944173. Are there other way I can verify the engine?
Thanks so much you guys. My heads apparently were removed and switched so the #'s were aginst the fire wall. I learned I have the proper engine and the heads were removed sometime in last 46 years. I am grateful
njot33
Sep 25, 2009 09:07 AM
cofield
Apr 14, 2009 02:14 PM
