66-67 Cutlass Exhaust Tailpipes
Old February 21st, 2024, 07:33 AM
Taz54904's Avatar
Next week, I am having a local shop make me a 2.25" dual exhaust for my 67 Cutlass Holiday Coupe. I'm looking for input (with photos) of how you have your tail pipes finished off. Do you have a straight cut or a 45 (I'm not sure if that's the exact angle, just throwing out a number here)? Do you have them exiting with a turn down and an angle cut (similar to factory) or do you have them exiting straight out and beyond the rear bumper?
My car currently has a single exhaust, exiting out the back but the tail pipe exits almost under the bumper, which makes the bumper show corrosion from the exhaust rolling up it.
My exhaust will exit towards the back of the car, like the single exhaust is.
The muffler shop said that they can do whatever I want, so I'm looking for options. Thx!
Taz54904 is offline
Old February 21st, 2024, 07:43 AM
fleming442's Avatar
45⁰ is a bit much; shoot for more like 60⁰. Personally, I prefer to dump them behind the rear wheels.
fleming442 is offline
Old February 21st, 2024, 08:22 AM
I have turndowns just behind the bumper. I do have to clean the bumper every so often from the exhaust residue.
oldcutlass is online now
Old February 21st, 2024, 12:11 PM
therobski's Avatar
Turn downs picture with 2.5's
therobski is online now
Old February 21st, 2024, 05:38 PM
Chrome, straight out the rear, tips cut at an angle (don't know degree of angle).
Dream67Olds442 is offline
Old February 22nd, 2024, 02:03 AM
Taz54904's Avatar
If you wouldn't mind measuring, how far beyond the bumper are yours? I like this look. 👌
Taz54904 is offline
Old February 22nd, 2024, 05:51 AM
Glad you like the look, thanks for the compliment. The upper edge of the Chrome tailpipe extends exactly 5-inches beyond the lower edge of the bumper. The Chrome tailpipes are 2&1/2-inch diameter. Good luck!
Old February 22nd, 2024, 06:51 AM
Taz54904's Avatar
Thank you for taking the time to measure. I appreciate it!
Taz54904 is offline
Old February 22nd, 2024, 07:12 AM
Can't go wrong with the factory 1966-67 442 exhaust tips.
joe_padavano is offline
Old February 22nd, 2024, 08:17 AM
Rallye469's Avatar
I love the way the factor did it. It's clean and purposeful.
Rallye469 is offline
Old March 7th, 2024, 08:58 AM
Taz54904's Avatar
This is what I ended up with. This back quarter photo makes it look like the tips stick way out, but they aren't that bad.
Taz54904 is offline
Old March 7th, 2024, 09:10 AM
Andy's Avatar
g
This is what I ended up with. This Beck quarter photo makes it look like the tips stick way out, but they aren't that bad.
If your happy with it then leave it, I believe I would have the shop that did it to pull the pipes up tighter to the bumper, and cut the pipes off an inch to inch and a half. They should easily do that for you.
Andy is offline
Old March 7th, 2024, 09:15 AM
Taz54904's Avatar
I just got it back today and had to run back to work after I took the car home, so I'm going to see if I like it as I get used to seeing it this way vs the tucked in single exhaust that was on it.
Taz54904 is offline
Andy's Avatar
This is how I did mine, Thats a Waldron factory exhaust they built, then I had to install and trim the pipes etc.
Andy is offline
Old March 7th, 2024, 12:48 PM
mpowell's Avatar
Hear Hear! This is what im running.
mpowell is offline
Old March 13th, 2024, 02:58 PM
Rmodl73's Avatar
Rmodl73 is offline
Old March 13th, 2024, 04:58 PM
fleming442's Avatar
One of my upcoming projects is to get tailpipes back on. Current plan is to slash cut the Pypes 3" to match the factory angle and make a polished trim ring. I'll post a pic when/if I get it done.
Old March 13th, 2024, 06:11 PM
oldolds88's Avatar
they call them bologna cut
oldolds88 is offline
Old March 13th, 2024, 06:42 PM
Thanks for the correct terminology. Nice to hear from another Michigan guy. I grew up in Battle Creek, but have lived in St. Louis since '83.
Old March 14th, 2024, 01:39 AM
fleming442's Avatar
Bologna cut? That's interesting. I've never seen bologna cut on an angle......
Old March 14th, 2024, 07:11 AM
Taz54904's Avatar
The more I look at the exhaust length and tip style that I chose, I'm leaning towards shorter tailpipes and angled tips.
Taz54904 is offline
Old March 14th, 2024, 08:43 AM
Oldsmaniac's Avatar
Make that cut will look much better IMO.
Oldsmaniac is online now
Andy's Avatar
Thus is a rooled tip extension I bought at auto zone and spot welded on, has a slight angle
Andy is offline
Old March 14th, 2024, 09:34 AM
Taz54904's Avatar
Looks good! That's what I'm looking into right now.
Taz54904 is offline
Old March 14th, 2024, 09:53 AM
Oldsmaniac's Avatar
This is what I did for my 67.
Old March 16th, 2024, 10:06 AM
fleming442's Avatar
So, in case anyone is interested, the factory angle appears to be about 54⁰.
Old March 21st, 2024, 11:35 AM
Taz54904's Avatar
The more I looked at the tips on my car, the less I liked them. I purchased a different set this week and hopefully I'll get some garage time this weekend and get them swapped out. Then I'll post a couple of pics of the new tips.
Taz54904 is offline
Old March 23rd, 2024, 06:07 PM
Do Damage
67CSConvert455's Avatar
67 CS convertible exhaust
I have a 67 CS convertible. When I first replaced the stock 330 with a C headed 455 the exhaust was built around that configuration. The exhaust starts with Pypes down pipes to a Borla X cross over. The mufflers are Hooker Aero-chambers to Flowmaster mandrel bend ‘over-axles’ to Classic Chambered Exhaust short Powerstick as resonators all in 2.5” In 1967 they came from the factory with resonators at the exhaust tip and I wanted to stick to that theme. With this set up and X-pipe I still had drone. After install at the exhaust tips the drone went away. My goal was a performance exhaust but quiet enough when the top is down.
67CSConvert455 is offline
Old April 12th, 2024, 04:40 PM
Taz54904's Avatar
I finally got around to changing out the tips, and I'm much happier with the angle tips.
The top photo was taken at a bad angle and makes the pencil tips look like wheelbarrow handles. LOL
The middle photo shows the new angle tip on the right and the left tip is the pencil tip.
The last photo shows the new angle tips.
Taz54904 is offline
Jacoz70442
April 13th, 2022 07:29 AM
Ihatefiberglass
December 23rd, 2020 09:32 AM
rickbmac
September 18th, 2017 10:49 AM
PM70
September 4th, 2017 05:32 PM
CharlieZ
May 12th, 2016 05:53 PM
Quick Reply: 66-67 Cutlass Exhaust Tailpipes
