'65 Cutlass Brake question...
Old Aug 17, 2009 | 08:08 AM
65az's Avatar
I also posted this in the brakes section... but figured it is probably better here due to the Cutlass experts on here everyday... Car originally had 4 wheel drum manual brakes. I pulled off the manual master cylinder and used it to replace a worn out unit on my '65 4 door. Now, I recently acquired a power master cylinder off a '66 that had the same 4 wheel manual brakes. From everything I read, this should be a bolt in set up that will work just fine. I have two questions though.. is it truly a bolt on set up, and there is nothing else that needs changed? Secondly, Where do the vacuum lines run to and is there a place to order these? OR is it just a standard size rubber line that I can get at the hardware store. Motor is non stock, '77 403
Old Aug 17, 2009 | 09:44 AM
And unfortunately I'm confused in both places...
What is your question, exactly? Are you asking about the master cylinder or the power booster? If your question is, can you put the 66 POWER brake MC AND booster on the 65 manual brake car, the answer is yes, but you will need to rebend the brake line to the MC to fit.
Old Aug 17, 2009 | 10:07 AM
The vacuum line goes to manifold vacuum behind the carburetor. Just use hose instead unless you are "restoring" the car.
Old Aug 17, 2009 | 05:01 PM
65az's Avatar
Thanks for the info... I hope to get it completely hooked up this weekend. Another question though... The booster looks like it has two vacuum lines that need to go to it? Do both of these come from the manifold?
Old Aug 18, 2009 | 06:28 AM
Hmm, that is interesting. As far as I know brake boosters use one manifold vacuum line going to them. Maybe someone else knows something I don't. If you have a pic that would be great.
Old Aug 19, 2009 | 01:10 PM
RAMBOW's Avatar
Ben
Don't forget to use the "OTHER" hole in the brake pedal for the pushrod clevis.
There are two holes in the brake pedal, Manual brakes use one hole, power brakes use the other one.
Old Aug 22, 2009 | 04:20 PM
65az's Avatar
ok... sorry it took so long.. here is a picture of the new/old booster/master cylinder with the vacuum hook up...
Secondly.. this is the manifold that is on the car...which has no spots to hook up a vacuum line that I can find.
Lastly... is this a bolt plug that I can change out to install a vacuum line?
Old Aug 22, 2009 | 05:14 PM
2blu442's Avatar
I've never seen two lines like that. If its not too late, I know you said you wanted to complete this over the weekend, this might be a good time to upgrade to a dual reservior master cylinder. With a single if something bad happens and you get a bad leak you'll loose the brakes on all four corners. If you have the dual reservior you'll only loose two at a time and still have some braking ability. Just a thought. John
About where to attach it to the manifold, I don't think the bolt you show in the last picture is to vacuum. The factory manifold has a fitting between the carb and the distributor. Do you have your PVC attaching at the base of the carb in the back? If not, that might be a good place for vacuum. I'd find a port as large as the big port on your booster fitting.
Old Aug 22, 2009 | 07:35 PM
I've never seen a check valve like that either. It does just pull out of the rubber grommet and you can insert a normal one instead.
delmontcrusier
May 28, 2023 07:37 AM
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
Del70
Aug 2, 2011 04:40 PM
jon69olds
Wheels and Tires
Feb 11, 2011 11:57 AM
