65 auto shift console question
Old Jul 9, 2020 | 02:32 AM
Ryans F85's Avatar
Seeker of knowledge
Well I tried the search, my 65 f85 might have been a manual judging from the hole in the tunnel. Now it has a th400 and hurst shifter. The car did not come with a console they don’t seem to manufacture these. Is there any interchange with other A-bodies? Even if it isn’t correct. I will make one before I spend 3-600 on one!
Old Jul 9, 2020 | 07:11 AM
If you're willing to fabricate your own console then you aren't concerned with keeping the car concours. $300-$600 seems like a fair price for an aftermarket console designed for a Chevelle. But what do I know?
If you don't have to get your hands on an OE or NOS console then you need to visit a local salvage yard. Hopefully you could find a 70s or 80s GM car with a console you could fit into your Olds. Use this website as a start:
https://www.car-part.com/
Old Jul 9, 2020 | 07:30 AM
Ryans F85's Avatar
Seeker of knowledge
It’s not that I don’t appreciate concourse but the 69 455 and th400 that came in it throw that right out. Looks and function are good enough for me. From what I’ve seen for consoles that’s
What they go for, I’m just not in it for that. Wish we had good junkyards up here but they rust away. I will try the link thanks. My comment on the Chevelle was that maybe the Chevy stuff is cheaper, it was the case in ford vs Chevy.
Old Jul 9, 2020 | 07:43 AM
RetroRanger's Avatar
72 Olds CS
Yes consoles are an expensive item as most are not reprduced. Here on classic olds theres paint dab restos as well as LS swaps.
for the most part im w you looks and function, on my car i have parts that are not “ correct” but fit and function fine and do the job i expect them to.
Old Jul 9, 2020 | 09:55 AM
stan 65 cutlass's Avatar
65 f85s did come with an automatic console if ordered, they are available used. the original shifter is prone to breaking though so not as easy to find in great shape. good luck
Old Aug 5, 2020 | 12:54 PM
Gerald Nickels's Avatar
A 67-72 Cutlass 442 shifter will fit into a 64-66 console. I would look at finding a 67-68-69 console with shifter on parts wanted.
Gerald
Old Aug 5, 2020 | 02:00 PM
Ryans F85's Avatar
Seeker of knowledge
Gerald
I have a hurst quarter stick shifter I was gonna use, I will keep an eye out for different console.
Old Aug 5, 2020 | 02:33 PM
The stock 1965 AT floor shifter used a lever and rod that went through a hole in the tunnel. A manual trans car would have had the mount for the clutch z-bar welded to the frame below the master cylinder.
Old Apr 2, 2025 | 07:50 PM
NightMoves810's Avatar
Sorry to bring this topic back from the dead but does anyone know how the 66-72 consoles fit the floor of the 64-65 cars? Any photos? Thanks
Old Apr 3, 2025 | 03:58 AM
Actually it's 1967-69 and the 1967 floorpan is the same as the 64-66.
Old Apr 3, 2025 | 05:44 AM
thank you, I didn’t mean to say the 66-72 was the same I was just curious how any of the consoles from 66-72 would fit the 64-65 cars
Old Apr 4, 2025 | 06:14 AM
My point was that 64-66 used the same consoles. 67-69 used the same consoles.
jerry63
Nov 17, 2018 10:04 AM
65cutlassnorth
May 11, 2014 07:28 PM
rlm765
Mar 15, 2013 07:58 PM
jjcus
Aug 10, 2012 09:23 PM
denis
Feb 22, 2007 11:51 PM
