64 Cutlass Odometer got stuck at 96,000.0
Old Mar 30, 2022 | 11:57 AM
rickrock999's Avatar
Crusin in my 6-4
Hi, Olds Guys.
I have a 64 Cutlass, when I bought the car about a year ago I noticed that the numbers
on the odometer were not lined up perfectly which I know means that at some point it was screwed with.
The engine on the car was rebuilt so who knows how many miles were on the car to start with.
Anyway when I bought it it had about 92,000 miles on it. The other day as it got to 96000.0
It got stuck. (see pic)
I have driven several miles or more and it has not moved.
Any ideas how to fix this?
Stuck Odometer
Old Mar 30, 2022 | 12:39 PM
lunaboy's Avatar
The Rocket Astronomer
dont know how to fix , but i have a unit available for sale . 200.00
Old Mar 30, 2022 | 03:02 PM
I had exactly the same problem with the odo on my 62. There are thin plastic or metal tabs in between each of the number wheels on the odo drum. If one breaks, the odo fails. I had to replace the drum with one from a parts car.
Old Mar 30, 2022 | 03:07 PM
69CSHC's Avatar
Stuck Odometer, or did the speedometer cable just go bad ... ?
Our cars are straight forward and uncomplicated. Often the repairs needed are the bare minimum...
For example, don't replace the battery when it turns out it was just the terminals that were loose.
Old Mar 30, 2022 | 03:08 PM
If the speedo is still working it's not the cable.
Old Mar 30, 2022 | 03:10 PM
Crusin in my 6-4
Thanks Joe, Based on what I have read, I would have to remove the whole speedometer, possibly the whole dash?
I can probably find a new odometer or take to a place to fix. Worried about pulling out the speedo though.
Haven't tried anything like that...yet. I'm going to look at the manual but if you have any tips...
Old Mar 30, 2022 | 03:12 PM
Crusin in my 6-4
The Speedometer still works, the odometer just stopped turning. So I would assume the speedo cable is still good.
Am I right?
Old Mar 30, 2022 | 03:15 PM
Unfortunately it's not that easy on the 64s. The dash pretty much has to come out, or else you will be spending a lot of time standing on your head.
Old Mar 30, 2022 | 03:38 PM
69CSHC's Avatar
Am I right?
Yes you are.
Old Mar 31, 2022 | 08:16 AM
REO442's Avatar
I have had the speedometer assembly out for the same repair, it is less time-consuming and simpler to remove only the assembly. So much other stuff to access and things can go wrong. Good luck.
Old Mar 31, 2022 | 08:44 AM
Crusin in my 6-4
Hi,
Can you explain what you mean by "assembly"
Also if you could help me out with how you did it I'd appreciate it.
Great car by the way. I think the first time I have seen one in a 4 door
OK I looked in the book and saw what the assembly is, Looks like a big job to get it out.
Old Apr 6, 2022 | 10:00 AM
Crusin in my 6-4
Hey guys,
I had not driven the car in several days. I took it out this morning and the odometer started working again.
The first digit is still half way between 2 numbers but the miles are turning. It hung for at least 10 miles before it got going again.
Not perfect but with the amount of work to fix I'll take it for now.
Old Apr 6, 2022 | 10:01 AM
Hey guys,
That's exactly what happened on my 62. I eventually got tired of it and changed the drum.
Old Apr 6, 2022 | 10:05 AM
Crusin in my 6-4
Yes I'm sure I will get tired of it at some point and change the drum. I am thinking about adding a clock,
Don't know if the instrument panel needs to come out for that. If so I'll get them both done at once, eventually.
jmos4
May 20, 2020 07:54 PM
streetrod
May 28, 2017 01:38 AM
gearheads78
Feb 17, 2013 09:44 AM
jensenracing77
Oct 24, 2011 05:13 AM
Wasted
Apr 1, 2010 04:15 PM
