350 rocket
Old May 16, 2011 | 01:19 PM
rayfrausto's Avatar
350 rocket
i have a 350 rocket in a 77 cutlass i think it might be time for rebuilding.. check the compression and 1-2 were not at a good pressure.. when added oil they jumped up so it could mean that its time for a rebuild... how much should a rebuild look estimate out too i no its depending on whats rong with it.. i have 1200 saved right now and hoping that i dont have to go to much over that
Old May 16, 2011 | 01:27 PM
455man's Avatar
About $2000 for a stock rebuild. I'm one to run old engines til they are done though. Does it burn oil? How's the oil pressure? Try 20W-50 oil.
Old May 16, 2011 | 02:41 PM
rayfrausto's Avatar
im not to sure i havent drove it to much sence i got it... i no it gots a oil leak and i need to change the oil gasket so i contastly check the oil make sure its good.. when i got it it was runed on like no oil i changed it out emidently.. i left it at my mechanics tho and he did a compression test and he said it was low that he belives its time for a rebuilding soon... i was thinkin of just running it down too then rebuilding / replacing... so i can use 20w-50
Old May 16, 2011 | 02:46 PM
citcapp's Avatar
You bet, use the 20-50 and start looking around for a good 350 block buy it then start the hunt on e-bay, craigs list, and here for parts. You will be surprised on how many new parts are available for great prices when your not in a hurry to rebuild. There are also great used parts as well. I have done several engine rebuilds this way and have saved a bundle.
Old May 16, 2011 | 03:56 PM
rayfrausto's Avatar
Look for parts as in intake and all that good stuff? I'm new to workin on cars but I got a good friend who owns a shop and he is teaching a lot and so are forums... ya I'm not in a hurry to rebuild only if it totaly ***** on me witch I don't think it will..
Old May 19, 2011 | 12:11 AM
rayfrausto's Avatar
Okay you guys so I need some help... ima start looking for a new 350 should I buy a rebuilt one or search Craigslist ect.. for a used one ? Or is that to risky?
Old May 24, 2011 | 06:38 PM
rayfrausto's Avatar
So are dose a 77 cutlass have a th350 long or short tail
69OLDSCUTCONV
Feb 1, 2011 06:09 AM
cutlassKing
Nov 29, 2010 03:05 PM
gscott819
Jul 28, 2009 07:02 PM
esisson
May 22, 2008 07:47 PM
<Eddie>
Nov 1, 2005 07:30 PM
