1971 cutlass supreme, 350, 2bbl
Guest
Posts: n/a
I need help getting my Cutlass to start. Last season the starter began to not respond reliably to the key, though power was on. When the car would start it ran without problems. Over the winter I replaced starter/solenoid and renewed wires and batery, to no avail. With key on, ignition lights do come on. Can I by-pass the ignition switch, e.g. hot-wire the car to tell if this is the problem? There is also what I believe to be a starter relay. I cannot locate a replacement, it is a single pole device, can this be tested? Thanks in advance, David Adelberg
If you can get to it, you can hot wire from +12V to the "S" terminal on the starter solenoid. This will engage the solenoid and cause the motor to turn over. You still need to place the key in the RUN position to start the car.
I seem to have intermittent trouble similar to yours. 71 Supreme w/ console shift. All my power comes on but the ignition clicks once like a bad battery/connection. I take the steering column Sleeve (for lack of proper terminology) and twist it counterclockwise. Imagine the linkage between the console and the column is sloppy and stops it from starting. Works for me til I dig into it.
84oldsDelta88
January 3rd, 2012 03:57 AM
convert69
September 6th, 2011 06:27 PM
cutlass1972s
July 6th, 2010 07:33 PM
