1971 cutlass supreme, 350, 2bbl
Old Jun 27, 2008 | 06:23 PM
david adelberg
Guest
Posts: n/a
I need help getting my Cutlass to start. Last season the starter began to not respond reliably to the key, though power was on. When the car would start it ran without problems. Over the winter I replaced starter/solenoid and renewed wires and batery, to no avail. With key on, ignition lights do come on. Can I by-pass the ignition switch, e.g. hot-wire the car to tell if this is the problem? There is also what I believe to be a starter relay. I cannot locate a replacement, it is a single pole device, can this be tested? Thanks in advance, David Adelberg
Old Jun 28, 2008 | 12:17 PM
There was no starter relay used from the factory. The solenoid on the starter incorporates relay contacts in addition to the moving pole that engages the starter drive. Are you possibly thinking the horn relay is a starter relay?
If you can get to it, you can hot wire from +12V to the "S" terminal on the starter solenoid. This will engage the solenoid and cause the motor to turn over. You still need to place the key in the RUN position to start the car.
Old Jul 1, 2008 | 10:31 AM
Driftr's Avatar
My co-pilot for 30 years
I seem to have intermittent trouble similar to yours. 71 Supreme w/ console shift. All my power comes on but the ignition clicks once like a bad battery/connection. I take the steering column Sleeve (for lack of proper terminology) and twist it counterclockwise. Imagine the linkage between the console and the column is sloppy and stops it from starting. Works for me til I dig into it.
Old Jul 1, 2008 | 12:16 PM
If the problem is the backdrive linkage, there is a simple adjustment. There's a sliding fitting with a lock bolt at the bottom of the rod that comes off the steering column. Put the trans in park, loosen the bolt, push all the way upwards on the rod and hold it there while you tighten the bolt.
Old Jul 16, 2008 | 11:19 AM
Driftr's Avatar
Thanks Joe, will try it.
boese1978
Apr 23, 2012 07:46 AM
84oldsDelta88
Jan 3, 2012 02:57 AM
84oldsDelta88
Dec 21, 2011 06:45 PM
convert69
Sep 6, 2011 05:27 PM
cutlass1972s
Jul 6, 2010 06:33 PM
