Holy mother body roll!
Finally got my 71 running good enough to take it out on the road. The amount of body roll this thing has is ridiculous. I feel like it could flip if taking a corner at a decent speed. Has new shocks and struts all around. Springs are factory I think. No sway bar in the rear.
What can I do to cut down on this body roll?
A friend of mine has a 71' with really tall springs. I mean the car sits higher than normal. When you see him go around a corner that thing really leans bad. I've told him to get some shorter springs at least to stock level. He loves how it looks and doesn't mind the roll...I lowered mine 1 1/2"'s and it made a nice difference. Added some better shocks bigger front & rear sway bars and it handles good for a big girl.
1989 Mustang GT. But it had all aftermarket suspension.
I think my factory springs are pretty worn. It sits this low on factory springs.
An often-overlooked factor in the body roll feeling is that we only have(well, use) lap belts, making the g-forces much more affecting on our upper body as we go 'round a corner.
That being said, a new bushings all around, 1-1/4" front sway bar, rear bar, better shocks plus new springs, taller ball joints and tubular front control arms - in that order. Mine does roundabouts at 25 MPH like that.
X2 w/ NHolds & Seff - 1 1/4" front sway bar & new links, boxed rear lower control arms & stock rear bar for starters. That's the budget route that will make a big difference right away for calming sway.
After that you will have to address worn components & renew or upgrade from there but this is where appreciable money and/or labor will come into play. Bushings, steering components, shocks, springs, steering box are likely all in need of attention.
I was gonna ask the same question.
I agree with everyone else on springs, sway bars, and bushings. I installed stiffer springs on mine (already had rear sway bar, boxed lower control arms, polygraphite bushings) and it handles a whole lot better than it did with 40 year old worn out springs (duh!)
Moog 5536 up front and 5409 in back.
I replaced all the bushings, springs, boxed rear lower arms, added KYB shocks, changed to an 1 1/4 front bar" 1" rear sway bars and changed the steering gear to 12.7 ratio in my 65. My car will about make you sick now going up the mountain roads, it handles well.
Is the UMI front sway bar a good deal at 190$? I will be removing the rear soon to install posi and gears so MAW do control arms while its out so ill hold off till I got the money to order a whole kit complete with rear sway bar.
I don't know about the sway bar, I got Hotchkis on my car. However, I did buy UMI rear control arms and they seem to be really good quality and perfect fit. I don't see how can a sway bar be any different.
Sorry guys, front shocks - not struts :P First car ive ever owned with shocks so im not used to having SHOCKS in the front!
The Hotchkis bar is 240$, and the UMI seems to have a good reviews for the price so Ill probably just go that route.
Tedd Thompson
December 22nd, 2014 09:51 AM
Tedd Thompson
May 20th, 2014 01:58 PM
Tedd Thompson
April 24th, 2014 02:50 PM
