stiff steering after steering box replacement
Old May 21st, 2010, 04:18 PM
agtw31's Avatar
put a quick ratio box in the delta,now it feels like my power steering isnt working,steering is very stiff.
do i have something too tight?
is the box i put in junk?
agtw31 is offline
Old May 21st, 2010, 06:04 PM
Blk71SX's Avatar
did you completely bleed the system?
if so, the gear could be bad
Blk71SX is offline
Old May 21st, 2010, 06:13 PM
GM Enthusiast
OLD SKL 69's Avatar
If you have not done this yet, try turning the steering wheel all the way side to side a few times. (Easier to do if you have the front wheels off the ground) That should get rid of all the air in the system. If you still have the issue, then you could try backing off the adjustment screw on the top of the box to see if that helps.
OLD SKL 69 is offline
Old May 21st, 2010, 06:42 PM
agtw31's Avatar
it's still doing the same thing even after adjusting the box both ways.
there is even play in the steering
frigging junk
agtw31 is offline
Old May 21st, 2010, 07:07 PM
GM Enthusiast
OLD SKL 69's Avatar
Yep, it sounds like they gave you a junk box. Hope they honor the deal with a free replacement.
Old May 22nd, 2010, 10:36 AM
agtw31's Avatar
guy is sending my money back,went to auto zone and bought a new one
what i should have done in the first place
agtw31 is offline
Old June 3rd, 2010, 01:48 PM
Mikes65's Avatar
What brand is the junker---? we need to know so we can avoid that seller/brand.
Mikes65 is offline
Old June 4th, 2010, 05:44 AM
Yes, please let us know.
Olds64 is offline
Old June 4th, 2010, 06:15 AM
MN71W30's Avatar
I used a 90's Jeep box in my 65 Chev and it works better than any I've had before.
MN71W30 is offline
Old June 4th, 2010, 08:46 AM
I wonder if that swap would work on an Olds?
Olds64 is offline
Old June 4th, 2010, 09:51 AM
MN71W30's Avatar
It'll bolt right up. I had to buy an aftermarket rag joint and a high pressure hose from a 80 Camaro and flare one fitting. It's under 3 turns lock to lock.
MN71W30 is offline
Old June 4th, 2010, 10:50 AM
Interesting!
Olds64 is offline
Old June 12th, 2010, 02:20 PM
jwesterling's Avatar
steering box
I have a 64 cutlass.I dont know what kind of box it has but steers great only about 2 !/2 turns lock to lock.My problem is it turns sharper to the right than to the left.Any Help?
jwesterling is offline
Old June 12th, 2010, 04:53 PM
MN71W30's Avatar
You need to center the steering box then adjust the tie rods so the tires are straight.
Turn the steering wheel back and forth and find the center. Look and see where the tires are pointing, they should be straight. If they are turning to the right you need to adjust your tie rods to make them straight.
MN71W30 is offline
Old June 12th, 2010, 07:52 PM
cutlass steering
Thanks,I went out and tried to get box centered.You are right,the wheels are turned to the right a little.It seems to be off a little less than a 1/4 turn.I am just getting it on the road.Would you believe i paid 70.00 for front end aliment.The guy was only in business a few months.HUM i wonder why.Thanks again,I will let you know the out come. Jon
Old June 14th, 2010, 06:01 AM
I've thought about getting the following tool so I can do my own alignments:
http://www.summitracing.com/parts/SPS-91000/
Olds64 is offline
Arrowstorm
Suspension & Handling
25
July 29th, 2015 05:52 AM
4424me
May 13th, 2012 06:02 PM
Frank3
January 12th, 2012 06:08 AM
MN71W30
July 23rd, 2009 02:49 PM
Quick Reply: stiff steering after steering box replacement
