Do lowering springs require different length shocks?
Old August 12th, 2018, 05:32 AM
Rocket Fire V8's Avatar
My car is falling apart faster than I can restomod it. One of my 17 yr old Edelbrock IAS shocks blew a seal and lost its oil. Man, there’s a LOT of oil in those suckers! They were awesome shocks, but no longer manufactured. At some point I plan to change the rake by dropping the front an inch or two with different springs. Question is.....if I change the shocks now, will I have to get different shocks for the front when I lower it? Don’t want to buy shocks twice.
Rocket Fire V8 is offline
Old August 12th, 2018, 05:47 AM
Looking at your profile picture, your front is pretty low now. Look at how much of the shocks shaft is sticking out now, subtract the amount your going to lower and see how much would remain.
oldcutlass is online now
Old August 12th, 2018, 06:38 AM
Oldcutlass, you make a good point. I see a lot of pics on here where I think the car almost looks raised. I have original 51 yr old springs all the way around. They are all probably sagging like crazy. I wonder what height off the ground the body was when new. All I know is that when I’m done, I want the rake to be raised a little in the rear. Lots of ways to get there.
Old August 12th, 2018, 07:53 AM
Post some side shots of your car when you get a chance. As far as the stock height, someone with 67 service manuals will need to chime in. BTW min is lifted 2+ inches all the way around.
nj67
Suspension & Handling
August 5th, 2015 06:48 PM
Macadoo
42
August 1st, 2015 06:26 AM
teqdave
20
January 23rd, 2015 06:22 AM
BlueCalais79
June 19th, 2011 07:52 AM
Olds Dad
January 26th, 2011 12:50 PM
Quick Reply: Do lowering springs require different length shocks?
