Tool Definitions
Old Dec 9, 2010 | 12:14 PM
crzyjef's Avatar
Tool Definitions
I'll admit I snatched and combined these from another site. They're just too good to keep to yourself.
What the Haynes Manual really means:
Haynes: Rotate counterclockwise.
Translation: Clamp with vicegrips then beat repeatedly with hammer counterclockwise.
Haynes: This is a snug fit.
Translation: Clamp with vicegrips then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Clamp with vicegrips then beat repeatedly with a hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a can of WD40 (giant economy size).
Haynes: Retain small spring...
Translation: pingggg - "Jesus, where the hell did that go?"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part (and maybe a bandaid or two).
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with vicegrips then beat repeatedly with hammer.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it.
Haynes: Routine maintenance...
Translation: If it isn't broken, it's about to be. We warned.
Haynes: One wrench rating.
Translation: An infant could do this... so how did you manage to **** it up?
Haynes: Two wrench rating.
Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three wrench rating.
Translation: Make sure you won't need your car for a couple of days.
Haynes: Four wrench rating.
Translation: You're not seriously considering this are you?
Haynes: Five wrench rating.
Translation: OK - but don't ever carry your loved ones in it again.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha.
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some vicegrips and a hammer...
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"
Haynes: Carefully...
Translation: You are about to suffer deep abrasions.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: Yeah, right. But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Haynes: Everyday toolkit
Translation: aaa card & Cell Phone
Haynes: Apply moderate heat...
Translation: Unless you have a blast furnace, don't bother. Alternatively, clamp with vicegrips then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book, with the exception what you really need to do.
Common Tools and Their Uses:
1. Drill press: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
2. Wire wheel: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "^%$@!!!"
3. Electric hand drill: Normally used for spinning pop rivets in their holes until you die of old age.
4. Pliers: Used to round off hexagonal bolt heads.
5. Hacksaw: One of a family of cutting tools built on the Ouija board principle: It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
6. VICE GRIP Pliers: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
7. Oxyacetylene torch: Used almost entirely for setting various flammable objects in your shop on fire. Also handy for igniting the grease inside a wheel hub you're trying to get the bearing race out of.
8. Whitworth sockets: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2" socket you've been searching for the last 15 minutes.
9. Hydraulic floor jack: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
10. Eight-foot long douglas fir 4X4: Used to attempt to lever an automobile upward off a hydraulic jack handle.
11. Tweezers: A tool for removing splinters of wood, especially Douglas fir.
12. Telephone: Tool for calling your neighbour to see if he has another hydraulic floor jack.
13. Snap-on gasket scraper: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for removing dog feces from your boots.
14. E-z out bolt and stud extractor: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
15. TWO-ton hydraulic engine hoist: A handy tool for testing the tensile strength of bolts and fuel lines you forgot to disconnect.
16. Craftsman 1/2 x 16-inch screwdriver: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
17. Aviation metal snips: See hacksaw.
18. Trouble light: The home builder's own tanning booth. Sometimes called drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
19. Phillips screwdriver: Normally used to stab the lids of old-style paper-and-tin oil cans and squirt oil on your shirt; can also be used, as the name implies, to round off the interiors of Phillips screw heads.
20. Air compressor: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to an Pneumatic impact wrench that grips rusty bolts last tightened 30 years ago by someone at Husqvarna, and rounds them off or twists them off.
21. Pry bar: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
22. Hose cutter: A tool used to cut hoses 1/2 inch too short.
23. Hammer: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
24. Mechanic's knife: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing upholstered items, chrome-plated metal, plastic parts and the other hand not holding the knife.
Old Dec 9, 2010 | 12:25 PM
66ninetyeightls's Avatar
Land Yacht Captain
funny
Old Dec 9, 2010 | 12:39 PM
Originally Posted by 66ninetyeightls
funny
x 2:d:d:d
Old Dec 9, 2010 | 01:15 PM
citcapp's Avatar
sad part is I can relate to most of that Still funny though
Old Dec 9, 2010 | 01:18 PM
jpaulwhite's Avatar
LMAO!!! This s*it is soooo true. Specially the part about the acetylene torches. I have learned to keep SEVERAL fire extinguishers right next to me when we use those now
Old Dec 9, 2010 | 01:56 PM
Coltonis's Avatar
Hilarity!
Old Dec 9, 2010 | 02:14 PM
O.P.LARRY's Avatar
very very funny and SO true
Kaline
Apr 18, 2022 03:35 PM
scrappie
Feb 11, 2013 09:04 AM
Dan Wirth
Nov 12, 2009 10:38 PM
tim72
Drivetrain/Differentials
Apr 3, 2009 09:00 AM
jeffabarber
Aug 27, 2008 07:37 PM
