Old Aug 15, 2023 | 12:38 PM
  #50001
Swing away!
Old Aug 15, 2023 | 12:41 PM
  #50002
The Braciole looks absolutely delicious. Molto bello!!
Agree with Norm 100%! I probably can't pronounce it correctly, but I'd have no problem finishing off a large platter. Nice job!
Old Aug 15, 2023 | 12:44 PM
  #50003
Have you no consideration for others? You find enjoyment posting recipes which are absolutely delicious? The Braciole looks absolutely delicious. Molto bello!!
Norm, This is a new one on me. it sounds wonderful I just never herd of it
Old Aug 15, 2023 | 12:46 PM
  #50004
No hot sauce for me, though I will use tobasco sauce sparingly on wings, mixed with melted butter and honey. Great wedding story Chris. Highway Starr, looks good, too much garlic for me though I like to on occasion make spagetti. lasagna, or manicotta. I usually make my own sauce.
Old Aug 15, 2023 | 12:51 PM
  #50005
Dan - I'm a HUGE fan of simmering down tomatoes for marinara sauce. Absolutely nothing beats homemade marinara. A nice 1/2 bushel of tomatoes simmering on the stove for a 1/2 day seasoning along the way as you see fit.
I'm a huge fan of garlic - absolutely love garlic.
Old Aug 15, 2023 | 01:06 PM
  #50006
I like garlic, it don't like me. Acid reflux.
Old Aug 16, 2023 | 05:27 AM
  #50007
Old Aug 16, 2023 | 06:48 AM
  #50008
HighwayStar 442's Avatar
Yes. Would can tomatoes in mason jars with Mom & Dad. At the end of the growing season from the garden. Most were plum tomatoes. Cook, peel, deseed and boil in jars in huge pot. About 30 cases of quarts, a time consuming job. Would last until tomatoes were ripe the next year. But the sauce was amazing. Store bought tomato cans, are no match for taste. And oh yea bring on the garlic, big time. Have a old Italian recipe of making the best sauce. I would tell you the recipe, but would have to kill you after.
Old Aug 16, 2023 | 07:03 AM
  #50009
Originally Posted by Jamesbo
Someone had a GREAT imagination! 👍
Old Aug 16, 2023 | 08:21 AM
  #50010
Old Aug 16, 2023 | 08:38 AM
  #50011
Norm - As the "Church Lady" would have said, "Now isn't that Special". 👍
Old Aug 16, 2023 | 11:57 AM
  #50012
Had a small panic attack with my new( 150 hours] John deere 790 60" cut mower. Started digging up dirt, shut off blades and limped back to theee cleaning ramps. A few minutes later noticed flat tire on the rear. So I thought that was what was making it mow dirt. Jacked it up to level and removed tire . Took to get repaired but even at level still cutting into dirt
suspected bent blade or snapshot shafts. Called around to check parts availability and Called friend with hoist. He came and got it
turns out someone ran over steel wire that wrapped around shaft..Removed enough wire to choke a goat
Problem solved.
Norm. Do you use your motorcycle lift on your zero turn?
Old Aug 16, 2023 | 12:31 PM
  #50013
Jim - I park my Zero Turn on the lift. I have side rails and keep them attached. That lift has been a great addition to the man-cave. So easy to change blades, lubricate, change oil, etc. Any of my other ICE motorized equipment is so much easier to work on at waist level. Actually, anything is so much easier at waist level.
Old Aug 16, 2023 | 12:46 PM
  #50014
Norm What name and model number do you like? Do you know the max. weight? My sixty inch mower is Heavy
Old Aug 16, 2023 | 06:15 PM
  #50015
Jim - I don't believe they make my Model any longer, but I'm sure you'll find something of comparable capacity & pricing. I paid ~$1,350.00 It's both pneumatic and hydraulic. I generally use the pneumatic on a regular basis. I purchased it from a company called BendPak, 1645 Lemonwood Drive, Santa Paula, CA
RANGER MODEL NO. RML-750HD
Lifting capacity: 1,650 lbs
Lowered height: 7"
Platform raised height: 43"
Length – main lifting table: 80-1/2"
Length –– with side extensions: 88-1/2"
Width –– main lifting table: 29-1/2"
Width –– with side extensions: 53"
Old Aug 16, 2023 | 06:20 PM
  #50016
Old Aug 17, 2023 | 02:42 AM
  #50017
Tanks Norm
Old Aug 18, 2023 | 04:20 AM
  #50018
Headed Norte Have a great weekend Olds friends.
Old Aug 18, 2023 | 05:55 AM
  #50019
Have a great one and safe travels Jim!
Old Aug 18, 2023 | 10:20 AM
  #50020
Colorado River should be good rafting this weekend. Hillary will NOT play well.
Old Aug 18, 2023 | 10:25 AM
  #50021
I’ve witnessed complete dry beds in/near Riverside/Palm Springs become rivers 1-2 miles in width w/in a 24 hr period. Very wild indeed.
Old Aug 18, 2023 | 12:36 PM
  #50022
I understand the topograpy and the nature of the arroyos in that area very well. Around 1995 or 96 I worked on a very detailed mapping project centered on the Marine Corps Base at 29 Palms.
Old Aug 18, 2023 | 03:23 PM
  #50023
otto72's Avatar
Not sure if it was on this site that I was introduced to this guys channel or not. Anywho I have been enjoying some of the uploads he has been producing. Check it out if you want.
Beautiful day here in Wisco. 48deg this am and warmed up to maybe just 80 low humidity nice breeze. Went to the Steam and Gas show with the new Electric Cart and checked out the tractors, saw mills, Big Boy Steam engines etc... Talked with some interesting old duffers, mostly just listened and soaked it in. This piece gave me an idea for a way to display some of Grandpa's (On both sides) tools I have in the shop just sitting in wooden boxes right now. Gett'm up and out on the wall to look at end enjoy.
Old Aug 18, 2023 | 04:09 PM
  #50024
Keith - Your weather sounds gorgeous. It's still very oppressive heat/humidity here. I like the tool art work - should be fun to create something similar.
Old Aug 18, 2023 | 05:36 PM
  #50025
otto72's Avatar
Norm- Sounds like you have been having a struggle with that hot oppressive weather for some time now, it is really old real fast I am sure.
Yes the wall art gave me some ideas. I will more than likely lay it out flat get a pattern of sort then use some tie wire maybe to connect things. I don't have a welder or the heart to weld on tools with the sentimental value these have to me. There was a real creative wood carver that shared some of this buildings space I did not take any pictures of his pieces, just cool.
Old Aug 18, 2023 | 06:01 PM
  #50026
Maybe a metal (or wood) lattice - like a rose bush lattice, or something similar - then hang the pieces on the lattice. Another thought is a chain (two or more) hanging from ceiling/rafters, etc. with tools hanging from tie-wire on the chain. Thought anyways.
Old Aug 18, 2023 | 06:18 PM
  #50027
otto72's Avatar
Yes I will have to tinker a bit and see what transpires. A saw blade, or large sprocket in lieu of the clock of the one pictured would be a good fit. That clock looks too new
Old Aug 18, 2023 | 06:39 PM
  #50028
The clock is certainly out of place as in far too new.
Old Aug 18, 2023 | 06:44 PM
  #50029
Previous 48 hour loop of Ms. Hilary
https://www.star.nesdis.noaa.gov/GOE...ength=48&dim=1
Old Aug 18, 2023 | 06:57 PM
  #50030
Keith - That's a really cool piece of garage art, thanks for sharing! Hope you can find a neat way to display some of your family heirloom tools.
Old Aug 18, 2023 | 07:50 PM
  #50031
Hey guys,
Our little town of Pevely is having their summer festival this weekend, it actually started Thursday and goes thru Saturday evening. My oldest daughter, SIL, and their kids (3) met us downtown at the festival this evening so the 2 older kids could enjoy the kiddee carnival rides.
Grandma with our newest Grandson Rowan, 3-months
Me with Ollie, SIL Mike with Anna, and Rowan just cruisin
In conjunction with the festival they are having a Car Show in the City Park tomorrow morning that we're going to. Sunday I'm taking the car to a show in the little town of Maeystown, IL to benefit 1st Responders. Should be a fun weekend, although the temp spikes tremendously on Sunday. The forecast is for close to 100° Sunday.
Hope ya'll have a great weekend!
Old Aug 18, 2023 | 08:18 PM
  #50032
I’m hoping we might actually get some rain from this. My landscape vegetation is barely hanging on. Even the prickly pear cactus patch is wilting. You know it’s bad when the cactus is suffering.
Old Aug 18, 2023 | 09:00 PM
  #50033
You're sitting right on the Eastern edge of any significant rainfall from Hilary. I think the Inland Empire of California might get a pummeling. Hopefully you'll get some moisture however it arrives you sure need it.
Old Aug 19, 2023 | 10:36 AM
  #50034
Well at least there’s some cloud cover this weekend and for the first time in over 2 months we’ll cool down to 100 degrees.
Old Aug 19, 2023 | 10:41 AM
  #50035
July was brutal and summer ain’t over yet. We still have 2 1/2 months to go.
Old Aug 19, 2023 | 02:00 PM
  #50036
^x2^
Old Aug 19, 2023 | 05:12 PM
  #50037
^x2^
^x3^
Old Aug 19, 2023 | 07:29 PM
  #50038
Hi guys,
Went to the Pevely Days car show today and there was a great turnout. It was warm but I had a nice place to park with some shade which made it nice. My buddy with the '66 Vette came so I had great company, and my oldest daughter and her family that we just saw yesterday evening came for a little while. Grandson Ollie had a great time driving Grandpa's hotrod.
If you want to check out the car pics you can find them here:
https://classicoldsmobile.com/forums...3/#post1518514
I really wanted to go to that show in Maeystown, IL tomorrow, but it's supposed to be 103° with a heat index of 115°. No thanks, that's too much, even for me. We're headed into another week of extreme heat with highs near 100 for the next 4 or 5-days, doesn't look like fun. I'm blaming Kenneth!
Hope everyone has a great Sunday!
Old Aug 19, 2023 | 08:19 PM
  #50039
^x2^
^x3^
^x4^
Old Aug 19, 2023 | 08:27 PM
  #50040
The poor bastards in San Berdoo/Riverside might wake up in Chula Vista Monday morning if Hilary remains on track. This will not be pretty.
