'96 Ply. Voyager front sway bar eyelet broken.
A friend has one of these & the front sway bar eyelet on one end snapped. Not the sway bar end links, but the sway bar itself. The eye is still attached to the end link?
. It obviously needs a sway bar & while there, end links, but I've never replaced a front sway bar on one of these. Don't know how hard or not hard it is. Any one done one of these &/or have a picture of the bottom of the front of one of these by chance? I haven't stuck my head under there to see yet, just being lazy asking for advice first. If it's easy, I'll just get one from a yard & do it but if it's a pita, off to a shop it goes.
Not too bad to replace the sway bar . Price after market places like NAPA or Advance auto parts for a new sway bar kit . Ithink the last few I did the replacement bar was a solid bar instead of a hollow bar and it also included bushings . You may need to drop the cradle just a bit for clearance but if it only has front haet and AC Ithink you don't need to . GOOD LUCK ,TOM ........
I've done a few. Should be fairly easy & straightforward. Since it's a grocery/kid getter, and not a performance vehicle, might just want to get a used one from a yard. Could save a few bucks on the job. That's where I'd look first. 15 y/o minivan probably isn't worth the bucks for a new one.
-Jeff
-Jeff
