Steering shaft
Old Aug 13, 2014 | 06:34 AM
deadeyejedi's Avatar
Steering shaft
Can anyone tell me how to remove the intermediate steering shaft on a 1980 cutlass supreme ? I've removed the bolts in each end of it and assumed it slid toward the firewall in order to slide off of the spline at the lower end but not budging . Do I need to remove the steering box?
Old Aug 13, 2014 | 07:11 AM
If you've removed the pinch bolt at the bottom of the steering column (below the brake booster), you need to push the housing with the flex joint down towards the front of the car. The splines often stick if the shaft has never been off the car before. Sometimes it helps to pry open the clamp that the pinch bolt goes into to loosen the splines. You might need to apply judicious force...
Old Aug 13, 2014 | 07:31 AM
Thanks Joe I'll do just that
Old Aug 13, 2014 | 10:52 AM
tru-blue 442's Avatar
Old School Olds
[QUOTE=joe_padavano;733184] You might need to apply judicious force...
Correct me if I am wrong Joe.
This means BFH, yes?
Old Aug 13, 2014 | 11:02 AM
Somthin' like that...
Old Aug 14, 2014 | 09:39 AM
Nothing doing on spreading shaft clamp and driving downward there seems to a a small rod going inside the middle of the splined shaft and extending into the intermediate shaft it's about an eight of an inch in diameter any clue what it is ? If I pound like hell on it I'm going to bend it
Old Aug 14, 2014 | 10:55 AM
Ok I got it shaft had to be slid up toward firewall in order to pop knuckle off that piece is just another part of the spline .
Old Aug 14, 2014 | 03:57 PM
If you are talking about the large housing on the LH side of this photo, that comes off the splines with the rest of the steering shaft. The housing is a combination slip joint and u-joint. The cross pin you talked about fits into two square blocks that pivot on the pin and slide up and down in the housing. The housing itself has the splines and pinch bolt that fits over the bottom of the steering column shaft. The shaft you removed should look like this photo.
Old Aug 14, 2014 | 04:14 PM
your exactly right .of course it all made sense once it came out. the car is in a dimly lit garage with no drop light very limited tools and covered with grease . reminds me of the old days
Old Aug 14, 2014 | 04:48 PM
steering link
this is the best pic i have regarding that pin just posting it in case someone else runs into this
Old Oct 16, 2024 | 03:35 AM
79cut's Avatar
anyone know a good place to buy one of these shafts for steering ?
Frogge467
Mar 24, 2012 11:09 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
#1CutlassSupreme
Jun 5, 2009 09:22 AM
7244too
Nov 6, 2008 09:27 AM
Joesgarage
May 29, 2007 08:25 PM
