1965 Cutlass Sway Bar Question
I'm pulling apart a 65 Cutlass chassis. I've noticed the front sway bar looks pretty thick. On a lot of my old GM cars (late fifties, early sixties)I've found the 6 cyl cars came with no front sway bar. Just wondering if the 65 f-85 6 cyl cars were the same with Olds. Would the Cutlass front sway be desired for another type? Maybe Chevelles or other A-bodies came with no front stabilizer bar, or maybe a thinner one.
Trying to decide whether I should take it off or not. Anyone know about this intriguing possibility
Hi Stan,
No rear sway bar. I've got to buy one for the 442, as it's missing. Have you got a front one on your parts car for the Cutlass, or do you want me to save this one for you?
Is it like the old Chevs, where you have to actually change the lower control arms as well?
i guess i do have a front one, found this pic of odd chalk marks i found on my car, yes the rears have need the boxed lower control arms to mount a sway bar, your 442 will have em if still original
65 cutlass do I need the frame reinforce? ??? because frame looks weak
I have a good 65 cutlass that was a v6 but. Who ever had it put in a olds 455 motor so I just check the cars fram because I want to make a limited slep and I saw the frame looks very week is stright and good just looks lil week do I have to get it reinforced? And around how much would that cost?
